Perhaps the Euro J stand is longer (the one with the dog leg in it) or possibly an 1100R one.
What have you got?
Mine is 11 inches bolt centre to toe tip.
zorded wrote:Thanks Chris i remember you looking at this before.
Did you get as far as measuring an 1100R one or are they the same at 11 inch.
Hello Al, Had a similar issue after raising the back end of my 1000j by 40mm, soon found out I needed a longer stand. All my research was fruitless...nothing! Worked out that it needed to be 330 long. So I cut it just below the peg for the spring, fabricated a piece of tube ( bottle jack handle I think Laughing ), lined it all up and welded it, little bit of work with a flap disc, couple of coats of grey primer and paint and job done....and you can hardly notice
the joints.. Give it a go! Wink
