Not starting !!!
z1000puddin
Not starting !!!
#1 PostAuthor: z1000puddin » Thu Apr 16, 2015 8:43 pm
Guys
I need a bit of help here
I have just finished fitting a new gearbox to my 1075 zed
I have spark at the new plugs
I have compression @ 150 across all pots
Fully charged battery
Dyna ignition & dyna coils
29mm smoothbores
I have only had a loud backfire and then nothing????
Any pointers to where I need to start checking 👿😩
Stu
Zed til Dead
steve bowdler
#2 PostAuthor: steve bowdler » Thu Apr 16, 2015 8:58 pm
Fuel Supply good ?
#3 PostAuthor: z1bman » Thu Apr 16, 2015 8:59 pm
was it running ok before you removed the engine? did you just part the cases & not touch the top end? check your coils & ht leads or wired correctly
z1000puddin
#4 PostAuthor: z1000puddin » Thu Apr 16, 2015 9:24 pm
z1bman wrote:was it running ok before you removed the engine? did you just part the cases & not touch the top end? check your coils & ht leads or wired correctly
It was running well before I stripped it
The barrels were left on. The head was removed & All the valves were left in place & I checked the clearances were all 4 thou on reassembly
The HT leads are all numbered and were hung to the front
I tried swapping the black and green coil wires but no difference
There is fuel in the bores but there doesn't seem to be a great deal as the plugs are not wet.
I tried a naked flame into the plug hole and it did cause a flame out
Confused or what
I may have to go back to the start and double check
Stu
Zed til Dead
#5 PostAuthor: z1bman » Thu Apr 16, 2015 9:37 pm
backfiring it normally associated with ignition or valve timing but your compression is good so i would doubt it would be down to that but it would wise to double check it
garyd
#6 PostAuthor: garyd » Fri Apr 17, 2015 7:33 am
Check your spark is firing at the right time.
I had this years ago when I fitted a Z1100 ignition plate to a GPz1100 by accident.
#7 PostAuthor: Ginger Bear » Fri Apr 17, 2015 7:50 am
Does sound like your ignition timing may be 180 degrees out. But as you say, you've already tried swapping the ignition wires around. :?? :??
# 104
1962royp
not starting
#8 PostAuthor: 1962royp » Fri Apr 17, 2015 8:17 am
try swapping the coil power leads over from one coil to the other if its 180 out it will either backfire or run.
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
z1000puddin
#9 PostAuthor: z1000puddin » Fri Apr 17, 2015 8:33 pm
Thanks guys for all the relevant pointers.
I got the old girl back to life the night.
My problem was the black Bob Weight spacer on the dyna ignition.
The advance weights were not correctly located in the 2 grooves😳😳😳
Started first prod of the button.
I am still not 100% happy as it seems to run better with the choke fully on ??
It is still popping & farting with the choke off.
I got fed up with it tonight & I will have a further look tomorrow
Stu
Zed til Dead
Users browsing this forum: Bing [Bot] and 70 guests
