Got a rattle
Bullhead
Got a rattle
#1 PostAuthor: Bullhead » Thu Apr 23, 2015 7:29 pm
The bike has a rattle coming from the engine. You can feel it slightly through the frame on tick over. When i give it a tiny bit of throttle it seems to die down. When i am riding you cant hear it. It sounds like the cam chain. What do you think? Thanks
steve bowdler
#2 PostAuthor: steve bowdler » Thu Apr 23, 2015 7:35 pm
Are the carbs balanced ? adjust camchain :??
#3 PostAuthor: zed1015 » Fri Apr 24, 2015 6:54 am
Also could be clutch rattle which is common.
As with the previous reply, balancing the carbs should help as well as checking and adjusting the cam chain tensioner if that is the source of the noise.
Bullhead
#4 PostAuthor: Bullhead » Fri Apr 24, 2015 7:09 am
Thanks. Will do those this weekend
garyd
#5 PostAuthor: garyd » Fri Apr 24, 2015 7:35 am
Also' if it's a clear 'Clack' that fades in and out at tickover, it could just be the camshafts moving slightly. I've had that on quiet a few Zeds.
#6 PostAuthor: Pigford » Fri Apr 24, 2015 7:38 am
Also - check the fuel tank ain't touching the frame and making a din - has been known :!:
weaver
#7 PostAuthor: weaver » Fri Apr 24, 2015 2:11 pm
Loose exhaust headers can sound like a rattly camchain too
Bullhead
#8 PostAuthor: Bullhead » Sat May 02, 2015 4:17 pm
Thanks all
nw66
#9 PostAuthor: nw66 » Sat May 02, 2015 5:50 pm
Pigford wrote:Also - check the fuel tank ain't touching the frame and making a din - has been known :!:
X 2 happened to one of mine :up
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
sid123
#10 PostAuthor: sid123 » Sat May 02, 2015 6:32 pm
loose engine mounts - loose exhaust flanges - loose alternator ?
whoosh im gone
#11 PostAuthor: ZedHead » Sat May 02, 2015 9:22 pm
Ignore - ride - enjoy :D
Users browsing this forum: Bing [Bot] and 67 guests
