Hi, can anyone tell me if the rectifier on a4 was rubber mounted at all please ?
Bolting it on underneath battery box but schematic drawing shows only a metal washer.The bolt is protruding well into the battery box to the point it's almost flush with rubber dampers that battery sits upon.Just thought it would be rubber mounted in some way ? Cheers g
Mounting rectifier a4
case
no case on the a4 just rubbers ...smaller bolts needed.
Just re-read G's first question, think he means regulator.
All the Zeds use a battery case including tha Z/KZ900A4 A5 and LTD's.
Part number 32099-015 BOX battery.
Why would the A4's not use a spill tray when other models before and after do?
The ZPower parts book was compiled by ZPower, has faults (remember his faulty book, has faults)
Bugga me can see why ZPower got it wrong, below is from genuine Z1R D3 parts book - 21 RUBBER BAND, battery. WTF
