Tacho drive seals
Tacho drive seals
Hi Guy's, can you change the inner seal in this unit
outer O ring no problem but pissing oil from the centre seal. Is this available as a kit or whole assembly, anyone got info on this and where from.
Hi Phil,
Take a look on these pics. You can see the inner and outer seal and the part number you need.
Think it is picture 16 as you scroll down
From Mark
http://www.zedrider.co.uk/z1-b.html
From Mark
This should be the same for a Z1R I would thinkpertonpc wrote:Hi Phil,
From Mark
Users browsing this forum: No registered users and 94 guests
