Aftermarket front sprocket cover
Robw
#1 PostAuthor: Robw » Sun Jun 07, 2015 8:21 pm
I am after fitting an aftermarket front sprocket cover as I am using a different clutch set up, so I don't need the actuator. Has anybody used a PMC one or similar? i have spotted one from an American Company called Precision Metal Fabrications, are they any good?
Cheers Rob
garyd
#2 PostAuthor: garyd » Sun Jun 07, 2015 9:41 pm
PMF covers are fine. Not flashy but they do the job.
davido
#3 PostAuthor: davido » Sat Jun 13, 2015 5:37 pm
D&G,also american,I think;
http://www.dgchassis.net/Outer%20bearin ... pport.aspx
Or make one yourself,after all its just a plate of aluminium with some holes drilled in it. Im making one at the minute.
http://www.kzrider.com/forum/11-project ... ?start=120
No idea what Im doing but it seems straight forward enough and its a lot cheaper than sending off to america for.
http://www.kzrider.com/forum/11-project ... ject-build
KZ1000CSR
GSF600Bandit
CBX750F
CB550F
