1000a1 removing rear wheel bearings
Hi. Hoping for inspiration. Am trying to replace old wheel bearings. Have removed seal and circlip but can't get any decent contact on bearing to drift it out because it's tight against the hub sleeve 42010-030. Any help appreciated
z1000 a1
Try using a rawlbolt by screwing into the bearing then you can knock it out with a drift
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
GPz 305 project
1981 KZ1000 LTD
I use a half round punch to get on the lip of the old bearing,push the spacer to one side to get purchase on lip of bearing..
Re: z1000 a1
1962royp wrote:Try using a rawlbolt by screwing into the bearing then you can knock it out with a drift
I have done this also. If you get a decent sized bolt in then knock it out.
LE to JOG on a z900
P.U.M.
P.U.M.
z1000 a1
I can get them out with a drift but we are not all Mechanics are we thats why i suggested the rawlbolt it makes it easy for someone that doesnt fix things all the time.
Get the threaded bar type not the bolt you can use it with a big socket and another nut and pull it out if you so wish .
GPZ1100 B2 owner
GPz 305 project
1981 KZ1000 LTD
GPz 305 project
1981 KZ1000 LTD
Hasbeen wrote:What's the correct tool for the job?. I work in engineering. Have access to presses lathes etc but still can't get a clean purchase on the bearing to drift or press it out. Am gonna try the rawbolt method when I can get my hands on one the correct size
Must be civil engineering
- z1000puddin
tedsonthezed
No need to spend hundreds on the correct tool. I recently bought this set to do the wheel and swing arm bearings on my ZRX.
http://www.ebay.co.uk/itm/9PC-BLIND-HOL ... 3396357356
What a bloody delight to use the right tool for the job, rather than bodge away with anything you can find - larger wheel axle on later bikes also means that the rawbolt method doesn't apply.
You want how much?
needaz1100r
- ZedHead
Users browsing this forum: kev edwards and 66 guests
