Progressive fork springs or not
Farmer
#31 PostAuthor: Farmer » Fri Jun 26, 2015 5:48 pm
Bugger, I wish I`d read this a week ago, I`ve just brought some Hagon progressive springs, is there any way of tweeking these or the standard springs for that matter on my LTD or is it bin everything and but some Linear ones :??
1981 KZ1000 K1 LTD
#32 PostAuthor: Al » Fri Jun 26, 2015 6:56 pm
I guess it depends exactly what you want to achieve and how you want to use the bike.
One possibility might be to put emulator valves in with what you have now.
Coose
#33 PostAuthor: Coose » Fri Jun 26, 2015 7:00 pm
As it's an Ltd I can't see you riding it like you stole it, so I'm sure all will be well with the Hagons.
Farmer
#34 PostAuthor: Farmer » Fri Jun 26, 2015 7:46 pm
Cheeky sod, I do at times ring it's neck, I'll see how I get on then , it said on the Hagon fitting instructions that if the springs were below the tubes fit the spacers and above the tubes do not, mine however are level with the tubes, I have fitted them, could I take them out for a slightly softer ride 😊.
1981 KZ1000 K1 LTD
Coose
#35 PostAuthor: Coose » Fri Jun 26, 2015 8:09 pm
No, the spring rate is the spring rate. You need to be measuring the static and laden sag to determine if you need the spacers. On an Ltd I'd say 15-20mm static sag, with 40-50mm laden.
I didn't mean to be rude, but you're not going to be in the fast group at a track day on an Ltd, are you? :wink: :shock:
Farmer
#36 PostAuthor: Farmer » Fri Jun 26, 2015 8:50 pm
You was not being rude at all, that tech went straight over my head, the spacers were supplied with the springs, so your saying keep them in then, the original's were ok riding but bottomed out every time you touched the brake hence why I changed them. 😊
1981 KZ1000 K1 LTD
Coose
#37 PostAuthor: Coose » Fri Jun 26, 2015 8:59 pm
How long are the spacers?
Farmer
#38 PostAuthor: Farmer » Fri Jun 26, 2015 9:09 pm
About 100mm from memory. 😊
1981 KZ1000 K1 LTD
Coose
#39 PostAuthor: Coose » Fri Jun 26, 2015 9:43 pm
100mm? Really? Definitely leave them in then.
Farmer
#40 PostAuthor: Farmer » Sat Jun 27, 2015 5:51 pm
I checked the oil level today and the spacers are 40mm not 4 inches, what air pressure would be best, I have been running them at 15 psi :D .
1981 KZ1000 K1 LTD
Coose
#41 PostAuthor: Coose » Sat Jun 27, 2015 5:57 pm
Try zero, then 15 and see which feels best for you. :)
Farmer
#42 PostAuthor: Farmer » Sat Jun 27, 2015 6:29 pm
Cool, thanks for all your advice Coose :D
1981 KZ1000 K1 LTD
alan bauly
#43 PostAuthor: alan bauly » Mon Jul 20, 2015 11:20 pm
Very interesting reading and just at the right time too. The Maxton kit sounds wonderful, particularly with external adjustment. Price is price, I've always believed in British engineering and there is no doubt Maxton do it right. If you buy quality you only have to buy it once.
The bigger the motor,the more expensive the bang !!!
#44 PostAuthor: Pigford » Tue Jul 21, 2015 6:24 am
ADMIN - CAN THIS THREAD BE MADE INTO A "STICKY" PLEASE
phil1r
#45 PostAuthor: phil1r » Wed May 04, 2016 10:18 pm
Z1parR wrote:
Taffus wrote:Got mine from Hagon plus the oil. worked a lot better than standard but still bottom out due to my excessive girth
:rir :rir
:shock: "O" Matron
