Hello,
Just to say, I am not that good a mechanic but I am trying to learn, so I may write things here that you may think are draft so please tell me I am grateful of the help.
I got the bike and since I have had it is ale=ways ran rough, lumpy, back fires etc. So I changed the plugs, caps, leads and coils. I have taken the carbs apart and cleaned them, and checked the jets, the float heights, the diagrams and it all looks good. BUt it is still the same. Then I checked the inlet rubbers- all OK. Now this is where I am getting confused- I put the vacuum gauges accross the carbs and turned over the engine and originally I only had a vacuum on No1, nothing on the others. So I assumed that there must be an issue with the carbs 2,3 and 4 not getting a vacuum , a leak or something- is that right?
Anyway so I thought, well No1 was ok, so I will take items off No1 and swop with No4 and see if it makes a difference. I swopped the diagramm, and the bowl, it made no difference at all. In fact nowwhen I turn it over I get no vacuum on anything.
I have ordered a compression tester, but when I block the inlet port off with a rubber glove, it will pop it, so I guess the engine is sucking. It does this on all cylinders. Also when I turn it over I do get compression through the plug holes.
I am completely confused now, and I realy dont know what to do. If anyone has any ideas that I can try I would be really happy. I just want to get it done so I can go out on it.
Thanks for reading,
Ian
Z1000 LTD rough running- help please
- new poster
- new poster
- new poster
Check out this site look down to where it says syschronise carbs,learnt lots of this site ,very good,have had similar probs with these cv type carbs meself.
Paul J
http://members.dslextreme.com/users/bikecliff/
Paul J
- new poster
