Calling all Z1-R owners
HowieD
#1 PostAuthor: HowieD » Sat Aug 22, 2015 9:20 am
Greetings
having a little bit of a memory loss with setting up the gearing on Horace.
can anyone tell me the speed at 4000rpm in top gear please ??
Ta Muchly
H :oops: wie
ADE
#2 PostAuthor: ADE » Sat Aug 22, 2015 9:39 am
I think with 15T front and a 33T rear should give you around 70mph.Why i rember this i dont know.Must have been when i was converting to 530?
Ade
KeithZ1R
#3 PostAuthor: KeithZ1R » Sat Aug 22, 2015 11:10 am
Standard gearing gives 70mph at 4000, does on mine anyroad :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#4 PostAuthor: Garry.L » Sat Aug 22, 2015 11:39 am
ADE wrote:I think with 15T front and a 33T rear should give you around 70mph.Why
Well you learn something everyday..... I never knew a Shed could do 70mph.
HowieD
#5 PostAuthor: HowieD » Sat Aug 22, 2015 11:48 am
Thanks Keith
#6 PostAuthor: Pigford » Sat Aug 22, 2015 2:08 pm
Final drive should be 1:2.2 .... think I'm running 1:2.15 on my Harris (19t - 41t) with 17" wheels and it's a good compromise - will pull a bit taller as they're nice & light :wink:
HowieD
#7 PostAuthor: HowieD » Sat Aug 22, 2015 3:06 pm
Oh bugger ! That's why I can't work I t out right ! I forgot
I changed wheels to 17inch.
#8 PostAuthor: Pigford » Sat Aug 22, 2015 3:11 pm
HowieD wrote:Oh bugger ! That's why I can't work I t out right ! I forgot
There ain't much difference in rolling diameter between old 19" and modern 17" wheels as the newer tyres have a deeper section (apsect ratio or summink like that) :!:
