oil leak from tacho drive
john
#1 PostAuthor: john » Fri Aug 21, 2015 8:00 pm
Hi Lads
Z1B any one havesany ideas about tacho drive leaking oil . Changed both seals which did not seem to make any difference . Would you know if l need a new worm drive or the complete unit holder and drive . Thank you , kind regards
John
#2 PostAuthor: z1bman » Fri Aug 21, 2015 8:06 pm
worm gear probably has grooves in it where the seal has rubbed replace it. give the holder a coat of sealant before you put it back in the engine use a fibre washer from the z650 to seal between the cable & the tacho drive
john
#3 PostAuthor: john » Sat Aug 22, 2015 10:03 pm
Great ,Thank you for that .
Kind regards John
#4 PostAuthor: kev edwards » Sun Aug 23, 2015 6:25 pm
Best thing to do is buy new seals a worm gear from Zed power cheap enough, anything else is just a temporary repair.
#5 PostAuthor: z1bman » Sun Aug 23, 2015 6:31 pm
fibre washer for tacho cable part no 92065-103
scott
Junior Section leader
#6 PostAuthor: scott » Mon Aug 24, 2015 6:51 am
I had the same problem....replaced the worm drive and its been fine since
#7 PostAuthor: ZedHead » Mon Aug 24, 2015 8:57 am
timhb
#8 PostAuthor: timhb » Mon Sep 14, 2015 8:25 am
I have a similar problem on my Z1b and need to replace.
There were several options here on the forum and just wondered if sorted and if so which route you took john ?
There was a link for seals to the Sansei site although a z650 fibre washer was also advised?
Did you replace the worm drive also from Z power?
cheers
