Brake Rotors
nicomkii
Brake Rotors
#1 PostAuthor: nicomkii » Sun Nov 01, 2015 11:48 am
What are people doing with getting their brake discs up to scratch. Mine probably have one more year then they will be too thin to be skimmed. There is a mob down here who refurbish using your original centres and original hole spacings but that comes at a price of $300.00 per disc so around $900 for all 3 (420 pounds )
What have others used and pricings, quality etc ?
#2 PostAuthor: ZedHead » Sun Nov 01, 2015 2:43 pm
Don,t try to skim the, they will chatter. Get a machine shop to surface grind them.
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sun Nov 01, 2015 3:12 pm
And if you get them surface ground make sure its to a fine finish as they will
still chatter.
Regards
Steve
#4 PostAuthor: PAULJAC47 » Sun Nov 01, 2015 3:55 pm
And probably squeal...some disc rotors are still available,z power do em i think..
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Sun Nov 01, 2015 4:55 pm
I tried 'refreshing' 3 brake discs for my Z1s and they either chattered or squealed. I was lucky enough to have collected 3 NOS units over the years and these have all now been fitted with no further problems.
I believe that the pattern items are as good as OEM ones too.
Regards
Steve
000zeds
#6 PostAuthor: 000zeds » Sun Nov 01, 2015 5:01 pm
Zeds-R-Us
nicomkii
#7 PostAuthor: nicomkii » Sun Nov 01, 2015 10:27 pm
Thats them, 6 hole centres as long as the hub diameter is the same. They don't mention A3 MkII but have emailed and also find out about shipping down under. Self drill I am guessing ?
#8 PostAuthor: z1bman » Mon Nov 02, 2015 12:09 am
z1 through to z1b have 6 hole mounting . z900 a4 onwards only have 4 mounting holes
nicomkii
#9 PostAuthor: nicomkii » Mon Nov 02, 2015 2:18 am
z1bman wrote:z1 through to z1b have 6 hole mounting . z900 a4 onwards only have 4 mounting holes
Yep and ZPower don't have the 4 hole mounts so looks like refurbing the current ones.
#10 PostAuthor: z1bman » Mon Nov 02, 2015 7:46 am
