XS tidy up.
Great bikes the XS650, love them. Your is coming on a treat
Decided to paint the underside of the mudguards and chain guard today, so I gave them a clean up whilst the mudguards were just all surface rust the chain guard was much closer to the original finish and a very poor one at that, the throwing power in the chrome plating bath was useless as you can see in the picture although you do not expect a perfect bright chrome on the inner parts it barely got over the edges, the nickel bath was good though as the whole inner surface has still got a good coating on it, you can see where the chrome ends in the pics, the more I do on this bike the more I realize that these bikes were absolutely not made to last a few years let alone nearly forty, late 1970s Yamaha workmanship is rubbish.
jimmock wrote:Kev,
I am more than impressed.
It is looking gorgeous.
What is your lathe in the back ground?
Cheers Jim, it is just a tidy up and I am using and just cleaning as much of the original parts without spending loads on refurbishment, if it got too nice I wouldn't use it, and I will run it all year round.
That's just a little 10'' atlas and does everything I need, turned out a couple sleeves for the rear indicator rubbers during the week, I used to have long Drummond round bed which believe or not was better for the small stuff as I could mill with it.
Bit more done today, also a question if anyone knows much about these, before the strip the harness's were very badly butchered and as soon as I switched the ignition on the lights came on, so I have replaced with new stateside ones, now when I switch the ignition on they are not coming on is this meant to be like this and they only come on when the motor is running, I know they have safety relays and would this explain why, I have also replaced the original generator with a new PMA.
Boyer on and running will need to strobe it up tomorrow.
https://www.youtube.com/watch?v=HedfcFST2v8
A short video shot with the phone of the old XS650 running pretty much as it should, a bit more carb work to do, the new 2 into 1 makes them sound really different.
https://youtu.be/f99aq4lWylE
Took the old girl for it's MOT today, i came away dead chuffed, passed with ease they adjusted headlight aim for me, the tester who is also a rider was impressed with the standard of work, and praised the bike and me accordingly, going to ride it for the summer and paint it during the winter now.
