frame and caliper paint
Mr Bump
#1 PostAuthor: Mr Bump » Fri Jan 01, 2016 2:11 pm
Good afternoon,
any recommendations for frame and various bracket paint on a z1000a1?
I want to replicate the slightly off gloss black (not satin) finish used on these bikes, as full gloss don't look right, which is probably why kawa didn't use it.
I'm a bit sniffy about powder coating because I don't know if the proper off-gloss finish will be available, and I've seen several instances where water has got into a chip in the finish and rust has propagated under the coating in a big patch. That said, it seems to be the solution with the least effort on my part.
I recently saw a Norton frame in a mates bike shop with a finish that was a dead ringer for a factory finish, that was apparently black smoothrite. I expect its a pain to do though.
The same goes for the black brake calipers - what's best? I'll almost certainly paint these at home though.
Thanks,
Olly
relisysxx
#2 PostAuthor: relisysxx » Fri Jan 01, 2016 3:56 pm
Had my fame and brackets powdercoated in 'matt plus 25% gloss' if that helps
#3 PostAuthor: PAULJAC47 » Fri Jan 01, 2016 4:02 pm
Go for Plasticote Barbeque paint for the calipers,though bake it on...
Mr Bump
#4 PostAuthor: Mr Bump » Sun Jan 03, 2016 8:42 pm
Thats good, thanks for the advice,
Olly
wheelysteve
#5 PostAuthor: wheelysteve » Mon Jan 04, 2016 2:09 pm
PAULJAC47 wrote:Go for Plasticote Barbeque paint for the calipers,though bake it on...
Is this stuff resistant to brake fluid when baked on ?
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Mon Jan 04, 2016 4:04 pm
frost extreme chassic paint for the frame and brackets
http://www.frost.co.uk/search?q=extreme ... is%20black
ADE
#7 PostAuthor: ADE » Mon Jan 04, 2016 8:14 pm
I use it for my Exhaust up to now the best i have used
Ade
Rob McCool
#8 PostAuthor: Rob McCool » Wed Jan 06, 2016 4:16 pm
I used PJ1 paint on my master cylinder/calipers and it seems very resistant to brake fluid. :D
Mr Bump
#9 PostAuthor: Mr Bump » Mon Jan 11, 2016 7:49 pm
Thats good, thanks for your help.
Olly
Users browsing this forum: No registered users and 106 guests
