non starter
michael thomas
non starter
Help my z1 ltd was having problems with missing and back firing so i tried some new leads which helped for a while but after it started doing the same again i took the coils off to check the connections and now it will not start seems to get one spark at the plug then nothing plugs are wet so its not petrol
michael thomas
- paul doran
- london calling
Check for a 12V feed to the coils and fit some DENSO W24ES-U.
Make sure that you've got the wiring to the coils 1&4 and 2&3 the correct way round.
Last edited by london calling on Fri Feb 01, 2008 7:20 am, edited 1 time in total.
Jack
Ok,connectors are ok and we maybe dumping plugs for densos.
BUT...........................
The quality and the condition of the cables also contribute to good conductivity.
ie if the copper strands are dull/matt or in fact black this aint gonna help.This is when breakdown occurs.
Example
Had a bike rewired it all Ok but no fire,went to the electronic pick up,farooked just at the moulding clean wires(whats left) and solder on some fresh cable. Still no go.
Traced the fault to the starter solenoid cable is matt and black.cut it but until got some decent cable connect,press tit........
VROOM
That is to say disturb old cable and it could be enough to cause breakdown.To test do a resistance check from end to the other.
Hope you get it sorted
Example
VROOM
michael thomas
Finaly got round to look at the z1 ,the plug leads on three and four were wrong plus a duff plug on one no wonder it would not have it! still not running one hundred so have decided to take it to a local bike shop because i just do not have the time will let you know the outcome thanks for all the help
michael thomas
Users browsing this forum: Tony and 30 guests
