Rearsets, advice please
LTD Project
#1 PostAuthor: LTD Project » Wed Feb 03, 2016 12:59 pm
I have a frame where the footrest bolt holes are, as best as I can measure, 46mm between centres. I want to buy some rearsets, how and where do I buy. Are they sold by this fitting measurement or are there other things to consider, offsets etc.
Any advice / recommendations to get something that might fit? Makes of manufacturer, Stockists etc.
KZ1000 B4 under light restoration.
#2 PostAuthor: chrisu » Wed Feb 03, 2016 2:09 pm
couple of options here.
either - modern footrests bolted to a triangular ally plate (which itself mounts on the original footrest stems). Lots of these from breakers. I've got a set of GSXR ones on my Z1R and they work well.
or something like Raask rearsets
#3 PostAuthor: Ginger Bear » Wed Feb 03, 2016 4:39 pm
Like this......
# 104
#4 PostAuthor: Ginger Bear » Wed Feb 03, 2016 4:42 pm
Or if you wanna give the plastic a spanking, WeBike will sell you these, that bolt straight on... :shock: :shock:
# 104
becker
#5 PostAuthor: becker » Wed Feb 03, 2016 5:46 pm
Disco Volante probably do a set of Tarozzi that will bolt straight on.
http://www.discovolantemoto.co.uk/tarozzi-rearsets-75-c.asp
When life hands you lemons, reach for the vodka.
Z1B (in Z1A colours), Z1000A1, ZRX1100 C4, Suzuki TS125J (being restored), Suzuki T125J (in boxes), Garelli Rekord MKII (awaiting restoration), most of a Garelli Rekord MKI
LTD Project
#6 PostAuthor: LTD Project » Wed Feb 03, 2016 7:49 pm
Oh wow, thanks...
I only have my phone at the mo. Wont be in front of the pc until Friday.
Goto to find something suitable from these posts. Cheers.
LTD Project
#7 PostAuthor: LTD Project » Wed Feb 03, 2016 8:48 pm
What make are they Steve.... They look expensive.
#8 PostAuthor: Ginger Bear » Wed Feb 03, 2016 9:25 pm
# 104
LTD Project
#9 PostAuthor: LTD Project » Wed Feb 03, 2016 9:28 pm
Ouch!
tlc
#10 PostAuthor: tlc » Thu Feb 04, 2016 2:46 pm
Ginger Bear wrote:They were :wink: ...... http://japan.webike.co.uk/products/21120626.html
And worth every penny.
Now where did I put the Loctite?
