clutch arm
Simon Jones
clutch arm
#1 PostAuthor: Simon Jones » Sat Feb 20, 2016 12:27 pm
I have been told that there is a longer clutch arm available that make your clutch lighter
Does any one know of supplier?
would suit my z1 and h2
75 z1b 75 h2c z1100r rd400 z1000a1 TS125
#2 PostAuthor: Ginger Bear » Sat Feb 20, 2016 2:40 pm
From memory the Unitrak clutch lifter arm was longer than the z1000J B1/B2 but I'm nut sure if you can fit the mechanism to a Z1.
Failing that, this works well...... www.z1enterprises.com/product/PM72-230
# 104
#3 PostAuthor: PAULJAC47 » Sat Feb 20, 2016 3:49 pm
That looks interesting,have you fitted one Steve?
Serps
#4 PostAuthor: Serps » Sat Feb 20, 2016 4:45 pm
I have one of these fitted and it does make it easier to use the clutch.
#5 PostAuthor: Pigford » Sat Feb 20, 2016 4:54 pm
Much cheaper to use a Falk hydraulic conversion.
#6 PostAuthor: Ginger Bear » Sat Feb 20, 2016 5:48 pm
PAULJAC47 wrote:That looks interesting,have you fitted one Steve?
Got one fitted to my current project, not managed to ride the thing yet, but the clutch does feel light and easy.
# 104
walshyco
#7 PostAuthor: walshyco » Tue Feb 23, 2016 8:45 pm
Ginger Bear wrote:From memory the Unitrak clutch lifter arm was longer than the z1000J B1/B2 but I'm nut sure if you can fit the mechanism to a Z1.
Great mod this (imo) Works really and easy to put back to standard if you want to, I have fitted two of these great service from Z1 enterprises as well.😊
#8 PostAuthor: z1bman » Tue Feb 23, 2016 9:35 pm
just extend your own 15mm it will make a big difference
Taffus
#9 PostAuthor: Taffus » Wed Feb 24, 2016 7:50 am
z1bman wrote:just extend your own 15mm it will make a big difference
Which bit? (and how?)
#10 PostAuthor: z1bman » Wed Feb 24, 2016 8:28 am
the arm that the cable is attached to. make another arm with some 3mm plate then remove the cable bracket by grinding of the rivet. weld the new longer arm over the existing arm then re attach the the cable bracket with a blind rivet or a cut down 6mm bolt & peen the end of the bolt so the bracket is free to move
Taffus
#11 PostAuthor: Taffus » Wed Feb 24, 2016 8:32 am
z1bman wrote:the arm that the cable is attached to. make another arm with some 3mm plate then remove the cable bracket by grinding of the rivet. weld the new longer arm over the existing arm then re attach the the cable bracket with a blind rivet or a cut down 6mm bolt & peen the end of the bolt so the bracket is free to move
My clutch on the A4 has a high bite point. I set it up as per the manual but it doesn't have the progression over the whole movement of the lever I'm used to
Garn 1
#12 PostAuthor: Garn 1 » Wed Feb 24, 2016 11:01 pm
That's interesting stuff Z1B, I never thought of that idea of extending the arm. I maybe thought it would not have the clearance for any adjustment of arm length. I suppose the downside (if any) is that your clutch lever travel for release would be slightly longer
RegardZ
#13 PostAuthor: z1bman » Wed Feb 24, 2016 11:47 pm
if you remove the cover you can measure how much clearance you have between the lifting arm & the bottom of the cover
johny brando
Up there for Thinking...Down there for Dancing !
#14 PostAuthor: johny brando » Thu Mar 10, 2016 6:14 am
Now , theres a common sense Idea's Man ! Luv your train of thought.....
Gold Star & a Curley Wurley to that man. Johny .B
Robw
#15 PostAuthor: Robw » Thu Mar 10, 2016 12:25 pm
I have a side pull clutch from Alan Cooper on my Z1000J with a later clutch fitted. I will need to go to the gym, to build up some muscles to operate it, so extending the arm may be a good idea.
Rob
