Dyna coils and MK11 ignition
Guys has anybody had any experience or issues matching 1.5 ohm Blue Dyna Coils to the standard MK11 exciter setup please ?
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Re: Dyna coils and MK11 ignition
KeithZ1R wrote:Guys has anybody had any experience or issues matching 1.5 ohm Blue Dyna Coils to the standard MK11 exciter setup please ?
I thought you needed 3 ohm (green)? Thats whats I run on my "J" and 1980 Z1000LTD B3/4
Dyna 2000 unit uses grey 2,2 ohm.
Your logic is good Mark but the J ignition coils run at about 2.8 ohms so 3 is good, the book states between 1.5 an 1.8 for the Mk11/ST coils, hence the ?
Keith
mistaken.
mistaken.
Taffus wrote:the 1.5 ohm dynas i have are red.... to be wired in series for a twin spark head
appears its a library picture, however to muddy the waters even more FFS the red ones are purported to be 6v
Keith
mistaken.
mistaken.
KeithZ1R wrote:Taffus wrote:the 1.5 ohm dynas i have are red.... to be wired in series for a twin spark head
appears its a library picture, however to muddy the waters even more FFS the red ones are purported to be 6vso as long as their part number is correct .....DC2-1 I suppose their the correct item, anyway back to the question ....anybody please
the cct diagram has them wired in series so 6v would be correct
Taffus wrote:KeithZ1R wrote:Taffus wrote:the 1.5 ohm dynas i have are red.... to be wired in series for a twin spark head
post script Dyna reckon the coils are not voltage rated and the 6v coils will be fine on a 12 volt system,sounds reasonable
Keith
mistaken.
mistaken.
njwmct wrote:I'm running 3 ohm Green Dynacoils with my standard Mark II ignition.
You need to remove the Ballast Resistor used with the standard MKII coils.
Been running like this for 3 years with no issues.
thats interesting, I didn't spot the Ballast so upon further investigation low and behold there it is, however when you check the bible the ballast and coil readings add up to 3 ohms in series so your setup is quite legitimate. The blurb states that as the coils are so low resistance the ballast is to limit the current to prevent overheating, its all clever stuff
Keith
mistaken.
mistaken.
KeithZ1R wrote:njwmct wrote:I'm running 3 ohm Green Dynacoils with my standard Mark II ignition.
Clever maybe - but pointless (sic) - why didn't they just leave the ballast out and use the "normal" (for Zeds) 3.0 ohm coils
Pigford wrote:KeithZ1R wrote:njwmct wrote:I'm running 3 ohm Green Dynacoils with my standard Mark II ignition.
That was my point Mark, design engineers usually have a valid reason for stuff... Its just not alway obvious and us mortals can only surmise and speculate, anyway im gonna get some 1.5 ohm coils and leave the resistor in place ... Cos I can
Keith
mistaken.
mistaken.
njwmct wrote:Keith,
Best to go for 3 Ohm coils without the ballast resistor because if a 30 year old plus MKII ignition fails at some point then 1.5 Ohm coils are no good for a Dyna S ignition.
Anyway, that was my logic for buying 3 Ohm coils.
Agree - less is more - the ballast resistor my go tits-up
njwmct wrote:Keith,
4 o clock logic took over this morning whilst suffering from insomnia so its the way I'm going
PS thanks for takin the time to read and answer guys
Keith
mistaken.
mistaken.
