Z THOU A2 FORK DISMANTLE
#1 PostAuthor: PAULJAC47 » Thu Mar 17, 2016 12:08 pm
Guyz refurbing z1000 a2 fork seals,got main spring out and looking down tube can see the damper rod,ones i have done before you can see a nut or a hex socket that a bolt head would fit in,this looks round ! have tried the broom handle trip no go? any tiips....??
KeithZ1R
#2 PostAuthor: KeithZ1R » Thu Mar 17, 2016 12:47 pm
get a round tapered drift and wedge it in a bit of tube then tap it into the hole in the damper rod :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
scott
Junior Section leader
#3 PostAuthor: scott » Thu Mar 17, 2016 1:07 pm
Paul.....I used a poker for the old coal fire....sounds mad but it worked
#4 PostAuthor: chrisu » Thu Mar 17, 2016 1:26 pm
Old broom handle
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Thu Mar 17, 2016 4:17 pm
I have the workshop tool and that does'nt work either the best piece of kit is a Gator grip socket on a long extension bar.
Works every time.
http://www.amazon.co.uk/Endeavor-20120A ... rip+socket
#6 PostAuthor: PAULJAC47 » Thu Mar 17, 2016 4:25 pm
Ther is nowt to grip on nut or hex inlet perfectly round,tapered broom handle worked for the one but had to make a tool out of a piece of square m steel stock tapered and spanked in to the rod,needed a rattle gun as well,found the tool kwak used on a j manual tools sheet ,look like the tip off an old gas heated soldering iron!Thanks for ideas!
#7 PostAuthor: z1bman » Thu Mar 17, 2016 8:17 pm
this is the genuine tool
#8 PostAuthor: PAULJAC47 » Thu Mar 17, 2016 8:34 pm
Yep thats the pic i have,is it a metal tapered tip? and what is the tip made from ? mild steel? i made a crude repro from m steel square stock...
popsA1
#9 PostAuthor: popsA1 » Thu Mar 17, 2016 8:37 pm
Made my own tool only a few weeks back from an M12 nut (19mm hex) welded to a length of 1/2" gas pipe.
A2 1979-80. A1 1980-now
#10 PostAuthor: PAULJAC47 » Thu Mar 17, 2016 8:43 pm
Thats no good for these forks Paul! tried one,hows the exhaust?
#11 PostAuthor: z1bman » Thu Mar 17, 2016 8:44 pm
there are two sizes one has a smaller taper & they are hardened steel i have half a dozen sitting in my toolbox
#12 PostAuthor: PAULJAC47 » Thu Mar 17, 2016 8:49 pm
Seems a step backwards this design from the previous types!
#13 PostAuthor: z1bman » Thu Mar 17, 2016 8:59 pm
they work prity good just tap it into the damper rod
#14 PostAuthor: PAULJAC47 » Thu Mar 17, 2016 9:02 pm
One i made did work ok, but did need a rattle gun to get the allen bolt out!
sid123
#15 PostAuthor: sid123 » Thu Mar 17, 2016 11:51 pm
whoosh im gone
Users browsing this forum: Robw and 61 guests
