ZRX Swingarm
RUDDY
ZRX Swingarm
#1 PostAuthor: RUDDY » Fri Mar 25, 2016 11:15 am
Gents, what mods does it take to fit a ZRX swingarm into a later Z, an 1100R for example :??
Is it nuts and bolts or is cutting involved ?
How does it effect chain offset ?
On a similar theme what is the easiest USD forks to fit ?
Just asking like......
85 Z1100R-1
#2 PostAuthor: chrisu » Fri Mar 25, 2016 1:52 pm
USDs - either GSXR1100 or ZX9Rs seem to be popular...
Robw
#3 PostAuthor: Robw » Fri Mar 25, 2016 3:03 pm
Swinging arm is a straight fit, all you need to do is make a spacer for the spindle. Off set seems fine with matching rear wheel. You do need to get an offset front sproket.
Rob
LeeJackson
#4 PostAuthor: LeeJackson » Fri Mar 25, 2016 5:26 pm
Ruddy
I'm just fitting one to my J. Waiting to get it back from powder coaters next week and I'll post some pics of what I'm planning to do to fit it. You can buy bronze bushings off the shelf to act like a spacer. I'm planning using these and changing the bearing for correct ID version, although closest you can get is one mm wider so need to see still how to fit that and get the circlip back in to retain it. Don't think it will be too big a deal.
Lee
RUDDY
#5 PostAuthor: RUDDY » Fri Mar 25, 2016 5:57 pm
LeeJackson wrote:Ruddy
Lee
Sounds good, plenty photos for us old timers to follow :D
85 Z1100R-1
floydsz1
#6 PostAuthor: floydsz1 » Fri Mar 25, 2016 7:06 pm
I will have this for sale shortly. Just taking engine out. If anyone's interested before it goes on evilbay. Zrx1100 swingarm etc etc
Charlie
#7 PostAuthor: Charlie » Sat Mar 26, 2016 1:52 pm
ZX9R upside forks are the way to go. They are longer than GSXR's etc and will work without either dropping the front end several inches, or needing slab yokes to gain a level ride. Those or ZZR14 forks are what most ZRX owners use to change to USD front ends. Plus of course, you keep it more Kawasaki than Kawa-uki :wink:
weaver
#8 PostAuthor: weaver » Sat Mar 26, 2016 3:50 pm
Zrx front end goes straight in upside downs wont look to good IMHO
LeeJackson
#9 PostAuthor: LeeJackson » Thu Apr 28, 2016 9:02 pm
Ruddy,
I just posted my simplistic approach to fitting the ZRX arm on my build page. Hopefully its clear enough.
Lee
