Leaky fuel tap
mikey
Leaky fuel tap
#1 PostAuthor: mikey » Tue Mar 29, 2016 1:42 pm
Just fitted a rebuild kit to my ltd 1000 fuel tap
And it still leaks could the tap body be worn out?
#2 PostAuthor: chrisu » Tue Mar 29, 2016 3:12 pm
Mikey,
Is it one of those taps with the conical insert that controls fuel flow.
if so they are next to impossible to get to seal once they develop grooves and start leaking in my experience.
mikey
#3 PostAuthor: mikey » Tue Mar 29, 2016 3:24 pm
Yes I believe it is chris if Im thinking what you mean.
Had the same problem with my gpz900r fuel tap
Still leaked after fitting a re build kit.
Hey ho new tap it is then.
