Thought I remembered seeing those two bearings somewhere?
Drive shaft bearing and Sprocket Bearing (cluster/ Layshaft).
Couldn't find them at ZPower or Z1Ent?
Where do Yu Getem ~ Gearbox bearings
Thanks Guys,
Managed to pick up the bearing I was really after. It was the thinner ball bearing on the output shaft. Original Read NSK BL305N.
Replacement was NACHI 6305-2NSE9NR. [Aust $28]
I had to remove the fibre dust covers To allow oil to penetrate, also it came with a full circle retainer ring.
RegardZ
RegardZ
