Rev Limiter Wiring - Dyna DRL200
#1 PostAuthor: Pigford » Wed May 11, 2016 7:05 pm
I am fitting a Rev Limiter to my Harris; it's a nice, simple bit of kit with just 4 x wires..... but I just want some advice to make sure I have it right (before frying me Dyna Coils). I'm running a Dyna S ignition (again, nice & easy).
Here's the wiring instructions:
http://www.powercommander.com/downloads ... DRL200.pdf
The bit thats not 100% clear (to me) is the connection of the BLUE & WHITE wires to the coils..... it doesn't show the feed from the Dyna S, but I assume the coils are kept the same (as without the rev Limiter) and just wired in for the Rev Limiter - added onto the wires? I think the Rev Limiter just shorts (grounds) the coil power input at the selected revs :?:
ADE
#2 PostAuthor: ADE » Wed May 11, 2016 8:09 pm
Looking at the diagram its the coils that cut the revs.Thats how i see it, give it the berries get to the blood line then it cuts the revs.
Ade
Taffus
#3 PostAuthor: Taffus » Wed May 11, 2016 8:38 pm
need the dyna s diagram
#4 PostAuthor: Pigford » Wed May 11, 2016 8:44 pm
Taffus wrote:need the dyna s diagram
Here you go Taffus lad :P
http://www.powercommander.com/downloads ... -1_2-2.pdf
Taffus
#5 PostAuthor: Taffus » Wed May 11, 2016 8:59 pm
give til tomorrow night and i'll draw a cricuit diagram (too many beers at the mo)
#6 PostAuthor: Pigford » Wed May 11, 2016 9:01 pm
You is da man :wink: Fanx
Users browsing this forum: No registered users and 103 guests
