Headlight fault Z900A4
Mowjoe
#1 PostAuthor: Mowjoe » Tue May 17, 2016 3:34 pm
Hi Guys, just getting the bike ready for mot. The headlight on full beam is bright but on dip goes dull. Then I found that on dip both the elements inside the bulb are both on at about half brightness. Any ideas why both elements are being powered up?
Z900-A4 looking like a Z1B!
#2 PostAuthor: z1bman » Tue May 17, 2016 5:53 pm
wiring configuration wrong? does it have a H4 headlight bulb
#3 PostAuthor: PAULJAC47 » Tue May 17, 2016 5:55 pm
You have the three wires going to the bulb crossed,swap them round till you get the it right!
#4 PostAuthor: z1bman » Tue May 17, 2016 6:03 pm
if its a H4 headlight the left terminal is earth . centre terminal is low beam right terminal is hight beam earth wire should be black with a yellow trace
Mowjoe
#5 PostAuthor: Mowjoe » Tue May 17, 2016 8:29 pm
PAULJAC47 wrote:You have the three wires going to the bulb crossed,swap them round till you get the it right!
Too simple, works perfect now, why didn't I think of that? Don't comment!
#6 PostAuthor: PAULJAC47 » Tue May 17, 2016 9:23 pm
Worked with electricity all my life,still had me thinking when i had exactly the same fault on a z thou i recently rewired,thats had i knew off the top of my head :??
Users browsing this forum: Bing [Bot] and 72 guests
