noisy top end after rebuild.
Bit stumped on this one.
Engine was quiet when bike was brought to me but smokey so has had a top end rebuild.
rebore/new pistons - all seems fine.
Head was rebuilt - new valves, guides and seals. Came back to me with valves etc all assembled. Also has all new camchain idler gears etc.
Fitted pistons, barrels, head, cams etc and timed up.
When I ran it there was a ticking noise from the top end - it increased with revs and is mechanical in nature. engine seems to run fine - no smoke etc.
Have dismantled the head and can't see anything obvious (like a sticking valve or loose valve guide) so before i reassemble and see if its 'gone away' - very unlikely any thoughts on possible cause ?
I've rebuilt loads of heads before and never had this symptom before.
I have fitted the cams in the head without the valves and there is no up/down play but there is quite a bit of end float.
Thoughts ?
Thoughts ?
- warren3200gt
- SVENLEATHER
- warren3200gt
http://www.z1ownersclub.co.uk/forum/vie ... ht=#275058
This is the thread when i was trying to diagnose mine. Might give you some pointers?
Users browsing this forum: Google [Bot] and 65 guests
