Paddock stand front
SVENLEATHER
Paddock stand front
#1 PostAuthor: SVENLEATHER » Sun Jun 12, 2016 1:26 pm
Hi,
Any recommendations on where I can get a front paddock stand to lift the front wheel up so I can remove it and remove the fork legs to replace the seals. It seems most front paddock stands are now two short to lift the front wheel and fork legs clear for removal.
FER
Auld Heedyun
#2 PostAuthor: FER » Sun Jun 12, 2016 1:33 pm
Get one of the ones that fits into the steering stem below the bottom yoke . The one I got has a selection of pins to fit various bikes , zrx and z1000 . Ebay 231611772539 should work . Not the same as mine but I can't remember where I got mine , probably at a bike show .
fer
#3 PostAuthor: Pigford » Sun Jun 12, 2016 1:49 pm
The type that fit under the front forks (at axel level) ain't much cop :|
Taffus
#4 PostAuthor: Taffus » Sun Jun 12, 2016 1:57 pm
I use a jack which I bought off bikerstoolbox. I jack to the frame and this raises the front wheel
http://www.bikerstoolbox.co.uk/acatalog ... IFT05.html
wheelysteve
#5 PostAuthor: wheelysteve » Sun Jun 12, 2016 3:39 pm
Chris, I've got a jack you can use or a main stand and bolts to do this job.
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
martinz1000r
#6 PostAuthor: martinz1000r » Sun Jun 12, 2016 4:55 pm
Taffus wrote:I use a jack which I bought off bikerstoolbox. I jack to the frame and this raises the front wheel
I also have one of these. Highly recommended. The type that goes under the headstock is good on modern bikes but my Z with big wheels and long forks doesn't have enough lift
#7 PostAuthor: Ginger Bear » Sun Jun 12, 2016 5:05 pm
I also have one of these jacks that sit under the frame.
I increased the height of the 'cups' so I could use it with the exhaust still fitted.
This is what you'll need;
http://www.ebay.co.uk/itm/20mm-Diameter ... 4d1f571148
http://www.ebay.co.uk/itm/M20-20mm-THRE ... 1a037f911c
# 104
Taffus
#8 PostAuthor: Taffus » Sun Jun 12, 2016 5:24 pm
I didn't need to as the one supplied by Ralph has enough reach to get around a Harris exhaust
