MDM wrote:In the meantime, I popped over to see Keith at Nasty Paint in Birmingham to pick up my finished bodywork. Here's a sneaky peak...
Old School!!!!
MDM wrote:So, after losing various parts in a house move last October, I did manage to find some bits that I thought were lost. Only now I come to actually start putting things back together I realise that I have lost more than I have found.
MDM wrote:As a thought - the calipers are ThunderAce 'bluespots' running on cast iron discs that're rather thicker than the usual modern sports bike discs, and there's not much clearance even when the pistons are pushed right back into their bores - a possible problem, or not?
warren3200gt wrote:Can you not put a chain tensioner on it to lift the chain away from the swingarm?
warren3200gt wrote:There is one that is spring loaded and mounts off the swingarm spindle tube. You can hardly see it when fitted. But........... I can't remember where I saw it or who makes it!
