Alloy pressed number plate fittings
bedlow1
#1 PostAuthor: bedlow1 » Sun Feb 10, 2008 8:17 pm
Another anal type question
can any of you lot remember?
Early pressed alloy rear black/yellow plates
The fittings - were they 2 zinc type nuts & bolts or were the current plastic bolt types used?
I assume they were zinc option as I guess the plastic type would have only come out when when the perspex plates became available around the later part of 1975.
can you enlight?
1972 Z1 Euro Spec
1975 Z1B UK Bike
MaineKZ
#2 PostAuthor: MaineKZ » Sun Feb 10, 2008 9:17 pm
MrB
Though I was still in my pushchair in the 70's, I do recall seeing quite a lot of bikes fitted with slotted panhead M6 screws - BZP finish.
Look more 'suited' to the job than a hexhead bolt:
#3 PostAuthor: chrisu » Mon Feb 11, 2008 10:39 am
i knew someone older than me would remember.................. :lol:
