Oil Cooler fitting
Fred the Zed
Oil Cooler fitting
#1 PostAuthor: Fred the Zed » Fri Sep 30, 2016 1:48 pm
Got a HEL 13 row oil cooler today... nice quality but of kit. A bit of simple fabrication to make it fit but I've struck on a problem I hadn't anticipated: The tacho drive cable is in the way.
Is there a simple solution? I don't really want the expense of having to buy an electronic tacho, but....
Fred
Paid Up Member
#2 PostAuthor: Ginger Bear » Fri Sep 30, 2016 5:56 pm
10 row cooler?
# 104
#3 PostAuthor: chrisu » Fri Sep 30, 2016 6:12 pm
photo ?
My oil cooler is 13 row and fits fine
Fred the Zed
#4 PostAuthor: Fred the Zed » Sat Oct 01, 2016 2:03 pm
chrisu wrote:photo ?
Are the cooler fittings on top or the bottom...? I think this makes the difference in terms of space.
Fred
Paid Up Member
Fred the Zed
#5 PostAuthor: Fred the Zed » Sat Oct 01, 2016 2:04 pm
Ginger Bear wrote:10 row cooler?
The thought had crossed my mind.... :twisted:
Paid Up Member
#6 PostAuthor: chrisu » Sat Oct 01, 2016 2:48 pm
Fred
Bottom
Fred the Zed
#7 PostAuthor: Fred the Zed » Mon Oct 03, 2016 10:29 am
Hi Chrisu...Did you dispense with the cable tacho drive then?
Fred
Paid Up Member
#8 PostAuthor: Pigford » Mon Oct 03, 2016 11:14 am
Best to have fittings on TOP if possible - helps retain oil to assist oil flow on start-up! Also enables more oil capacity in system as it don't flow back into sump :wink:
Fred the Zed
#9 PostAuthor: Fred the Zed » Mon Oct 03, 2016 2:34 pm
Pigford wrote:Best to have fittings on TOP if possible - helps retain oil to assist oil flow on start-up! Also enables more oil capacity in system as it don't flow back into sump :wink:
Hi Pigford
Do you know how to fit an oil cooler and retain the tacho drive?
Fred
Paid Up Member
#10 PostAuthor: chrisu » Mon Oct 03, 2016 3:05 pm
Fred
not at all
I'll dig a photo out for you. Bit old and been tidied up since but gives you an idea. Just clears the cooler bracket.
Fred the Zed
#11 PostAuthor: Fred the Zed » Mon Oct 03, 2016 5:55 pm
Fred
not at all
Thanks Chrisu
Did you drill the frame to fit the bracket then?
Fred
Paid Up Member
#12 PostAuthor: Pigford » Mon Oct 03, 2016 6:04 pm
#13 PostAuthor: chrisu » Mon Oct 03, 2016 6:09 pm
nope. used existing holes and a home made bracket.
Z1 frame.
Fred the Zed
#14 PostAuthor: Fred the Zed » Mon Oct 03, 2016 8:43 pm
chrisu wrote:nope. used existing holes and a home made bracket.
Z1 frame.
Okey doke
Paid Up Member
#15 PostAuthor: chrisNI » Tue Oct 04, 2016 11:32 am
I got a slightly longer cable made by some crowd that make cables, think it was about £20 quid
Users browsing this forum: moizeau and 38 guests
