Clutch basket shock absorber
sprint
#1 PostAuthor: sprint » Sun Oct 23, 2016 7:13 pm
Hi
Has anybody refurbished the clutch basket shock absorber springs or knows somebody/engineering firm that has/can or is there a kit available to do it?
The springs can/will become loose over time and whilst it may be possible to shim them to take up the play if replacement springs are not available it will be necessary to remove the baking plate to do so which requires removing and then replacing the rivets that hold the assy together.
Has anybody done this and can advise the rivets used or/and a source of replacement springs?
Andy
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Sun Oct 23, 2016 7:29 pm
Sprint try sending GEZ635 a pm as he used to offer this service including new springs to OEM spec.
Regards
Steve
sprint
#3 PostAuthor: sprint » Sun Oct 23, 2016 7:54 pm
Hi Steve
Thanks for the reply.
The springs that I am referring to are the ones on the back of the basket, see attached. Does your reply refer to the normal clutch plate springs?
Andy
[/img]Image
#4 PostAuthor: z1bman » Sun Oct 23, 2016 9:55 pm
clutch hub spring rebuilt kits available here you can also get it done at sep in kegworth derbyshire
http://kzzone.com/clutches.html
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Mon Oct 24, 2016 7:32 am
Andy,
Yes it does.
Regards
Steve
steve.w
#6 PostAuthor: steve.w » Mon Oct 24, 2016 5:50 pm
I have a refurbed comp clutch forsale :D
