KZ1000 A1 Engine & Frame Numbers - Can These Be Correct ???
pertonpc
#1 PostAuthor: pertonpc » Mon Oct 24, 2016 5:25 pm
Can I have some technical advice please Guys -
According to Z Power website a Z1000 A1 should have
frame no. KZT00A-027500 or less
engine no. KZT00A - 042500 or less
An actual bike (which looks like an A1) is showing these numbers
frame no. KZT00A- 5039** seems way too high
engine no. KZT00A- 0128** seems ok in the range
if the 5 was a zero it would be 003900 ish which would be in the range but seems way low compared to the engine.
Did I hear something about Lincoln Nebraska bikes getting a 5 in the number somewhere to denote USA built ??
Could these numbers have ever been supplied together from the factory on a Z1000 A1 machine ??
Please give me some pointers here people :oops: :oops:
Cheers from Mark
tlc
#2 PostAuthor: tlc » Mon Oct 24, 2016 5:49 pm
Everything you say is true Mark.
Re: KZ1000 A1 Engine & Frame Numbers - Can These Be Corr
#3 PostAuthor: Garry.L » Mon Oct 24, 2016 5:59 pm
Are you sure the A is not a B Mark?.... that would make it a 77 LTD on those numbers.
https://www.z1enterprises.com/store/mod ... 1000-77-81
pertonpc
#4 PostAuthor: pertonpc » Mon Oct 24, 2016 7:48 pm
Thanks Guys,
Not at all sure on anything yet Garry,
Not seen it in the flesh - only photos.
Are there any tell tale signs for a B LTD frame I could look out for ??
. . . so could numbers that far apart have been assembled like it at the factory :?: :?:
#5 PostAuthor: warren3200gt » Mon Oct 24, 2016 7:56 pm
Aren't the back end of the frames different on LTD's? Thought that was why LTD's are much cheaper because there is a lot of work to convert to make desirable. Or is that just 650's?
pertonpc
#6 PostAuthor: pertonpc » Mon Oct 24, 2016 8:13 pm
Warren
I think the LTD thou still had a duck tail - unlike the 650 versions.
I had an LTD 1000 seat fitted to a Z1 frame ok
I agree rear wheel was smaller size so I don't know where the difference if any lies.
Someone will be along soon to enlighten us I'm sure.
From Mark
#7 PostAuthor: Garry.L » Mon Oct 24, 2016 8:22 pm
pertonpc wrote:Thanks Guys,
Exhaust hangers on the LTD are very different to the A1.
I was always led to believe the engine & Frame numbers stopped being 'close' after the Z1b as the engines were then used in different models, ie A4/5 and Ltd etc.
pertonpc
#8 PostAuthor: pertonpc » Mon Oct 24, 2016 8:39 pm
Hi Garry,
A lad off another forum has just posted some A1 frame and engine numbers from December 1976 builds at the Nebraska factory - and they seem broadly in line with these
e.g. frame 503941 belongs to engine 012949
which is pretty close to what I am being quoted on this bike so it looks like it could well be legit.
if anyone has a piccy of a genuine A1 exhaust hanger frame bracket and an LTD Thou one to compare I would be grateful for either.
#9 PostAuthor: Garry.L » Mon Oct 24, 2016 8:46 pm
pertonpc wrote:Hi Garry,
Mark...
Pix on my for sale thread.
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=39125
Exhaust bracket on the A1 is one piece solid. Ltd is two tubes like the Z1 set up.
Gus
#10 PostAuthor: Gus » Mon Oct 24, 2016 8:59 pm
"Set the GRINDER on it"
pertonpc
#11 PostAuthor: pertonpc » Tue Oct 25, 2016 7:20 am
Great thanks lads.
The one I am looking at is a dead ringer for Garry's type of rear footrest hanger - not the tube type in Gus's picture so I think we are safe to rule out an LTD frame.
#12 PostAuthor: z1bman » Tue Oct 25, 2016 8:16 am
could be a mk2 frame ?
needaz1100r
#13 PostAuthor: needaz1100r » Tue Oct 25, 2016 8:24 am
pertonpc wrote:Warren
From Mark
1000LTD B1/B2 77/78 had a Z1000A1/A2 engine and Z1000/900A4 tailpiece.
1000LTD B3/B4 79/80 had a Z1000A3/A4 (MK2, square cam cover) Engine and Z900 Tailpiece.
1000LTD K 1981 onwards had Z1000J rubber mounted engine, distinctly different look with no tailpiece.
LTD B1-B4 had exhaust and footrest hangers similar to, if not identical to the 900A4,ie tubular not pressed steel.
Z1000A1-A2 side panels and tail piece are listed also for the Z1000 LTD B1-B4.
LTD has 16" rear wheel.
LTD has an odd shaped tank.
LTD has a strange headlamp bracket that bolts to the yokes and a horrid stepped seat, which needs a taller grab rail.
That, folks seems to be about it, unless anyone knows any different.
Looking for more info all the time.....
Mark.
Gus
#14 PostAuthor: Gus » Tue Oct 25, 2016 8:43 am
From memory
rear disc and spacer and rear caliper
rear mudguard front mudguard
Gus
#15 PostAuthor: Garry.L » Tue Oct 25, 2016 9:31 am
Some of the problem is that there are a lot of Ltd's about being passed off as Z1/A4's as it doesn't take a lot to make the former look like the latter.
However making a Ltd look like an A1 would be a bit more involved. So would it have been worth the effort doing in the first place?. Always worth checking though.
