Cracked Clutch Spring Plate
Cajones13
#1 PostAuthor: Cajones13 » Thu Nov 03, 2016 9:56 am
Popped the clutch cover today and spotted the outside centre has a webbing of fine cracks. They were not visible from the inside / push rod side, so not yet right through.
Has anyone else encountered this?
The only replacements I have found so far have been complete Z1000 J clutches for around $600 to 800AUD.
Has anyone tried welding one up?
12/78 Z1000 A3A frame running 1980 C3 Police
#2 PostAuthor: zed1015 » Thu Nov 03, 2016 10:45 am
Seen a few with what appear to be surface cracks like that (most likely casting fissures that have been there from new ) but never seen one fail and the pressure from the clutch mushroom is on a wider radius where the plate is much thicker too.
I wouldn't worry about it.
Cajones13
Reassuring!
#3 PostAuthor: Cajones13 » Thu Nov 03, 2016 10:51 am
zed1015 wrote:Seen a few with surface cracks like that (most likely been there from new) but never seen one fail and the pressure from the clutch mushroom is on a wider radius where the plate is much thicker too.
Thanks for that. I'm going to be putting an APE heavy duty clutch kit in and was a little worried the stronger springs might cause a failure.
#4 PostAuthor: warren3200gt » Thu Nov 03, 2016 4:02 pm
You could always JB Weld a disc in there. That would stop them spreading any further if your worried.
Cajones13
Good idea
#5 PostAuthor: Cajones13 » Thu Nov 03, 2016 11:40 pm
warren3200gt wrote:You could always JB Weld a disc in there. That would stop them spreading any further if your worried.
I might JB a stainless washer in for peace of mind I think. Tks
#6 PostAuthor: z1bman » Fri Nov 04, 2016 12:01 am
push rod length too long or clutch not adjusted correctly
Re: Good idea
#7 PostAuthor: zed1015 » Fri Nov 04, 2016 12:20 am
Gluing a washer to it won't do a thing except wreck the motor when it drops off.
I wouldn't use any chemical metal anywhere near the inside of the motor.
It's a BODGE and would be as effective as putting a plaster over a bullet wound.
That pressure plate won't fail.
We bore out that entire centre section when doing a rack and pinion clutch release conversion with no issues or loss of rigidity.
Cajones13
Re: Good idea
#8 PostAuthor: Cajones13 » Fri Nov 04, 2016 3:30 am
In that case I will relax and stop making problems for myself! Tks
Users browsing this forum: zapo and 81 guests
