What oil?
HarrisTZ
What oil?
#1 PostAuthor: HarrisTZ » Thu Feb 14, 2008 9:38 am
Hi chaps,
Does anyone have any clear recomendations of what oil to use on in a big oil cooled kwak.
Dean
#2 PostAuthor: chrisu » Thu Feb 14, 2008 11:21 am
if you do a thread search under engine oil you'll find chapter and verse on options and recommendations.
HowieD
#3 PostAuthor: HowieD » Thu Feb 14, 2008 5:50 pm
Hi,
I always used Mobil 1 in my Z1-R. used to give me improved fuel consumption. Used it since I first came across it in the 1990's. I thinks it's prolly overkill to use such a top of the range oil since its changed every 3000 miles. Once I get mine close to getting on the road I'll look into it again I suppose.
Hope that helps.
Regards
H
floydsz1
#4 PostAuthor: floydsz1 » Thu Feb 14, 2008 6:23 pm
Mate off mine says semi synthetic is fine, though some people recomend mineral oil. Me mate worked for tas suzuki as bruce ansty's mechanic and last year/this year is john Mcguiness's mechanic. He also races a P & M aircooled kawasaki so i tend to take his advice, I've run all my zeds on semi synthetic with no probs. Mineral is fine though aswell. suppose maybe its down to cost, plenty of others on here will give you advice though.
#5 PostAuthor: Pigford » Thu Feb 14, 2008 6:55 pm
I run with AMSOIL... Yankee Doodle Dandy stuff... from Debbens :twisted:
Bl**dy expensive, but its damned good, designed for performance roller bearing bikes, just like a Zed :wink:
Complete overkill if not tuned to the utmost, but HEY, peace of mind :D
If the motors not tuned, any old sh*te would be OK as long as you change it frequently :wink:
Synthetic CAN make clutches slip, unless specifically made for BIKES.
Also, synthetic can harm ROLLER bearing cranks, coz they make the ball bearings so slippy, they don't ROLL< but slip in the bearings, causing damage/wear :shock:
Pay's yer money, make yer choice :!:
Do a search on this site, as mentioned, LOADS of discussion about this :!:
floydsz1
#6 PostAuthor: floydsz1 » Fri Feb 15, 2008 11:17 pm
forgot to mention, obviously it should be a motorcycle oil not a car oil. car oils can make the clutch slip.
HarrisTZ
#7 PostAuthor: HarrisTZ » Fri Feb 22, 2008 10:35 am
HI,
Just wanted to say, I have just met Jack (jolly nice bloke), he has supplied me some TRM. I'll be trying that. So thanks for your reponses.
Thread closed for the momemnt.
Dean
london calling
#8 PostAuthor: london calling » Fri Feb 22, 2008 3:52 pm
No worries Dean,just watch out for L.F.T. and the Port :lol: :lol:
See you at Mallory :D
Can you post the CRMC dates on here,as other club members maybe interested in watching some classic racing.
Jack
ade woollams
#9 PostAuthor: ade woollams » Fri Feb 22, 2008 5:18 pm
10w40--20w50 gtx will work fine,think back to the days they where made and the oils that where around then .the engine was designed to run on that .maybe todays bikes need 'bike oil'just brainwashed x spence to get more cash from you.
my mate in the states has a mk2 z1000 from new has always run 20w50 gtx castrol the engine has never been apart and never had a problem with it ,he is close to 100,000 miles on it now he aims to pull it apart at that stage just to see what it looks like in there .he is an ex drarg racer so he dont hang about on it ,it get some stick .so car oils are just a myth i think .
Users browsing this forum: Tony and 33 guests
