From reading a few forums here I know a few of you guys like an old oil burner.
I've got an old 500 triple that needs a crank rebuild as it's been sat in a garage for years. Does anyone know where to get it sorted?
Oil Burner Crankshaft Rebuild
From the Triples forum....
I I can offer crankshaft rebuilds for all the triples and most other two strokes including avenger and samuari everything kept in stock for s and h series 250 350 400,500 and 750 including rods bearings and seals turnaround is normally 7-10 days
I also stock base gaskets for H1 and H2 in copper and I can also get made standard s series gaskets on request ,also I can get different thickness base gaskets made if you want to add a little hp to your motor
also full engine rebuilds if required
gary
07779094462
downpipe3@ntlworld.com
or....
Kawasaki Triple Engines. H1 and H2, plus S series Mechanical rebuilds .
Give us your motor, and we`ll strip, inspect and rebuild it for you ,
with a blow by blow picture documentary of the whole process.
We can take care of it all. From cleaning and polishing your cases etc
Supplying the pistons and rebore, organising the crank rebuilds , and
rebuildng gearbox and clutches. Rebuilding with all new gaskets and seals
And replacement stainless screws,nuts & bolts.
Prices from £250 labour plus parts. Turnaround time is 4 to 5 weeks. Yes, really !!
( n.b. I say it`s a mechanical rebuild, as if you fit your own engine, you are responsible for finding the spark !!! )
Triples Workshop. Call Neil on 07785 115559 or message me through this site.
NB...
'aint used any of the above, simply linking over the info.
gary
07779094462
or....
NB...
