Question on charging testing
nicomkii
#1 PostAuthor: nicomkii » Sun Jan 08, 2017 1:10 pm
I am working my way through testing electrical components on the MkII. With the straight out battery test with no load (lights off) the test was perfect. 13.4v @ 2500rpm and 13.9v @ 5000rpm.
With lights on I get a static 12.7v across the whole rev range, no where in the test schedule does it mention with lights on/off. What do I take away from this ?
Nico
oldzed
#2 PostAuthor: oldzed » Sun Jan 08, 2017 1:43 pm
My z1000st was similar.
Found that the stator windings were showing fine with no load but broke down when under any load .
check the ac output between each of the yellow wires. They should all be around 50v if I remember correctly.
As an aside I used a zxr400L stator in my St and it gives 14.4v now.
They are also cheap as chips on Ebay.
Buy a new wiring gromet and new connectors if you get a zxr one.
The wiring is slightly thinner so cut the multi plug off and coat the wires in
silicone sealer . Pull the pires through the new grommet then let it set before refilling with oil
member number 0664
Who can catch a Kawasaki?
A police helicopter
KeithZ1R
#3 PostAuthor: KeithZ1R » Sun Jan 08, 2017 3:10 pm
at 12.7v on full load the system is supplying what it needs to run the lights ignition and keep the battery "topped" so don't fuss to much
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
