Z1000J Build
tlc
#121 PostAuthor: tlc » Sun Jan 22, 2017 6:22 am
LeeJackson wrote:Cheers Vic! I take it the wife immediately understood the situations seriousness! :) mine just said "you should stop building bikes, there is always a problem". Haha
It puzzles me why they would say this.
The fact is we would only get under their feet if we just hung around the house moping.
I feel your pain with the head Lee.
LeeJackson
#122 PostAuthor: LeeJackson » Sun Jan 22, 2017 5:16 pm
Ah you know how it goes Chris, you can never win! :)
LeeJackson
#123 PostAuthor: LeeJackson » Sun Jan 22, 2017 5:25 pm
Some other small progress today though. Got my new machines sprocket carrier thanks to Coose.. Had to recess the studs slightly to sink them in a little further and got it fitted. Unfortunately my straight edge doesn't fit in between the carrier and the wheel now to check alignment but looks spot on.. Will have to get something else to check with tomorrow.
Also got myself a pre made rear caliper carrier to make life a little easier, over racing one and seems excellent quality. Also easy to change the adaptor plate if I want to use something other than a brembo 2 pot, but to be honest I think I'll just run with the Brembo. I wanted AP all round but they don't seem to want to do bikes anymore and seem to have stopped making most calipers.. So will just be another hassle. The over racing carrier is pretty clever, they made it reversible so can be top or bottom mounted. I will just need to figure out a torque arm now, needs to be short and offset a bit, so standard REX one I don't think will give me any offset?
#124 PostAuthor: Ginger Bear » Sun Jan 22, 2017 7:18 pm
A lot of older Suzuki stuff will have an offset, I've used these in the past & it's not difficult to 'tweak' the offset.
http://www.ebay.co.uk/itm/Suzuki-GSXR-6 ... Swh-1W6oLx
# 104
LeeJackson
#125 PostAuthor: LeeJackson » Sun Jan 22, 2017 7:21 pm
Good tip GB! My zephyr one has right offset just way too long. Could cut it I guess but these Gixer ones look much shorter so could be worth a punt..
#126 PostAuthor: Ginger Bear » Sun Jan 22, 2017 7:25 pm
Mounting hole centres are around 255mm.
# 104
LeeJackson
#127 PostAuthor: LeeJackson » Sun Jan 22, 2017 7:31 pm
Ah quiet long then still, I need a little short thing like a ZRX, around 170mm centre to centre..
#128 PostAuthor: Ginger Bear » Sun Jan 22, 2017 7:59 pm
How about a couple of stainless rose joints and some aluminium rod?
# 104
LeeJackson
#129 PostAuthor: LeeJackson » Sun Jan 22, 2017 8:04 pm
Yep that could be the answer, would save an awful lot of hassle!
Coose
#130 PostAuthor: Coose » Mon Jan 23, 2017 9:04 am
That looks grand Lee, and I'm glad all appears to be well with the carrier. :)
Mark Stratton
#131 PostAuthor: Mark Stratton » Mon Jan 23, 2017 1:52 pm
Kendo on the ZRX Owners Club forum makes these in different designs. This one is for a standard ZRX1200 set-up. Quality workmanship and if I remember rightly less than £35.00 delivered. Supplied with the necessary nuts, bolts and split pins.
LeeJackson
#132 PostAuthor: LeeJackson » Mon Jan 23, 2017 1:58 pm
Mark Stratton wrote:Kendo on the ZRX Owners Club forum makes these in different designs. This one is for a standard ZRX1200 set-up. Quality workmanship and if I remember rightly less than £35.00 delivered. Supplied with the necessary nuts, bolts and split pins.
Mark, that looks nice. Do you have a contact for him? I could ask if he can make a bent one :)
Lee
LeeJackson
#133 PostAuthor: LeeJackson » Mon Jan 23, 2017 9:53 pm
Coose wrote:That looks grand Lee, and I'm glad all appears to be well with the carrier. :)
Coose, 0.07mm runout on the sprocket.. Damn good job mate! :) If only my discs were this good!
Coose
#134 PostAuthor: Coose » Tue Jan 24, 2017 7:45 pm
That's great as far as your sprocket is concerned, but sadly doesn't help your discs....
But, I wouldn't worry about a tiny bit of disc run-out. You may not feel it, and as the late, great John Robinson stated a little is no bad thing as it will push your pads away from the disc, reducing drag. You have nothing to lose in trying them....
#135 PostAuthor: Pigford » Tue Jan 24, 2017 8:05 pm
Coose wrote:But, I wouldn't worry about a tiny bit of disc run-out. You may not feel it, and as the late, great John Robinson stated a little is no bad thing as it will push your pads away from the disc, reducing drag. You have nothing to lose in trying them....
Conversely, too much runout and you won't have enuff travel in the lever to take the slack back up and work the brake.......... just saying :wink:
