ZRX 1100 swing arm in a Z1000A frame
RussG
#1 PostAuthor: RussG » Sat Jan 28, 2017 7:52 am
Hi,
I'm fitting a ZRX swingarm in my Z1000 and am wondering which is best, reem the frame for a ZRX spindle or change bearings to take a Z1000 spindle?
Anyone know where I can get a stainless or titanium example of either spindle as well?
Russ
000zeds
#2 PostAuthor: 000zeds » Sat Jan 28, 2017 9:09 am
I think it would be better to change bearings to suit Z1000 spindle
Zeds-R-Us
steve.w
#3 PostAuthor: steve.w » Sat Jan 28, 2017 9:19 am
you cant get bearings to fit the standard spindle just sleeve the swinger bearings to fit youre 1000 spindle :wink:
LeeJackson
#4 PostAuthor: LeeJackson » Sat Jan 28, 2017 10:13 am
Russ check my 1000J build out I sleeved the ZRX arm with off the shelf bronze bushes, very easy to do and change the roller bearing (that needs to be ground down a little)
LeeJackson
#5 PostAuthor: LeeJackson » Sat Jan 28, 2017 10:17 am
#6 PostAuthor: Ginger Bear » Sat Jan 28, 2017 1:13 pm
# 104
Charlie
#7 PostAuthor: Charlie » Sat Jan 28, 2017 3:41 pm
Unless you already bought the swinger, it'd be better to get hold of a ZRX1200 swingarm. The 1100 took a 170 profile rear tyre which are limited in choice. The ZRX12 used a wider wheel and took a 180 rear tyre. The wheels wont interchange without a chunk of work either .....
RussG
#8 PostAuthor: RussG » Sat Jan 28, 2017 5:17 pm
Thanks GBear, your project has the answer to everything!! Superb piece of work 👍🏻👏🏻😃
RussG
#9 PostAuthor: RussG » Sat Jan 28, 2017 5:20 pm
Already bought the arm from Meerkat a couple of months back Charlie
RussG
#10 PostAuthor: RussG » Sat Jan 28, 2017 5:47 pm
Sorry guys, it was Lee's project not GBears, I was trying to be clever on my phone but my eye sight let me down, back on the pad now the update has finished..
weaver
#11 PostAuthor: weaver » Sun Jan 29, 2017 5:35 am
Charlie wrote:Unless you already bought the swinger, it'd be better to get hold of a ZRX1200 swingarm. The 1100 took a 170 profile rear tyre which are limited in choice. The ZRX12 used a wider wheel and took a 180 rear tyre. The wheels wont interchange without a chunk of work either .....
zxr750 h1/2 wheels go straight in,5.5 inch for 180 tyre
Robw
#12 PostAuthor: Robw » Sun Jan 29, 2017 8:39 pm
Zrx 1200 wheel goes into the 1100 swinging arm, all I did was turn a spacer around and machine the rear brake The hanger is made out of tough metal, so you will need a good tool in the lathe. Look at the zrx owners site, they have all the details needed.
Rob
weaver
#13 PostAuthor: weaver » Mon Jan 30, 2017 4:22 pm
Zxr wheel needs no machining use wheel complete with zxr caliper hanger use Rex axle and caliper
RussG
#14 PostAuthor: RussG » Mon Jan 30, 2017 6:55 pm
Thanks guys, have a wheel ready and ordered the bearings and bronze bushes yesterday. Thinking I might let out thr swingarm by a mm since I bought sealed bearings, just need to find a caliper now...
Padders
#15 PostAuthor: Padders » Mon Jan 30, 2017 8:19 pm
My frames away at the moment having the top shock mounts relocated and a zrx1100 swingarm fitted by Rob. He makes race frames for a living and came highly recommended. I mentioned using top hat spacers so no reaming of the frame. He was not happy at that so I told him to do whatever he thought best. Will post pictures when I get it back.
PUM 13
Users browsing this forum: Bing [Bot], zapo and 39 guests
