My newly acquired '77 kz900a5
#31 PostAuthor: Ultim8pc » Mon Dec 26, 2016 4:46 pm
Actually Tony Archer couldn't have been less interested if he tried..
Told me to buy a seat cover from Z Power and do it myself....
#32 PostAuthor: Ultim8pc » Tue Jan 31, 2017 2:44 pm
Managed to source a decent conditon OEM RH sidepanel and badge to replace the aftermarket one which had no badge.
Zedorset
#33 PostAuthor: Zedorset » Tue Jan 31, 2017 3:11 pm
They are only original once. There must be a period seat out the somewhere!
#34 PostAuthor: Ultim8pc » Tue Jan 31, 2017 3:27 pm
Zedorset wrote:They are only original once. There must be a period seat out the somewhere!
True. I think I am going to get a new seat foam and recover the existing seat base.
Re: My newly acquired '77 kz900a5
#35 PostAuthor: Ultim8pc » Thu Jun 15, 2017 8:42 pm
So, finally got some time to start work on the 900.
Started taking bits off the to clean up and I think it will tidy up well enough.
Did the valve clearances yesterday, a couple were well tight and had to go down three sizes to get them in tolerance. (eek!). Cams lobes look in good condition.
Checked the compression with the engine cold and got 85/95/90/85 psi. Will have to start her up and check warm but the cold readings look respectable I think.
I look at sorting the oil leaks next (tacho drive, alternator wire and gear change shaft).
#36 PostAuthor: paul doran » Sun Jun 18, 2017 9:14 am
100 is the working range
You may have a few seized rings
Pour diesel or hot waste oil into bores and leave it for a few days
Then redo the compression test
#37 PostAuthor: Ultim8pc » Tue Jun 20, 2017 11:01 pm
Re-did the tests with some oil in the bores and got
115/120/120/125
#38 PostAuthor: Ultim8pc » Sat Jun 24, 2017 11:47 am
Stripped the carbs down to run them through the ultrasonic cleaner.
Again, other than the grot caused by leaky float bowl gaskets - they are in excellent condition with pretty much no wear.
Had a couple of screws that wouldn't come out without the use of the mole grips...
#39 PostAuthor: Ultim8pc » Tue Jul 18, 2017 6:04 am
Been a bit ill for the last few weeks, so not moved forward too much.
However, upon closer inspection the float needles are a tad work, so I have full refurb kits ready to fit.
Taken the sump off and it's all pretty clean with no crap in the oil pump gauze filter. Getting the old sump gasket off was a complete bastard as it was hard as rock..
Going to fit a new oil pump o-ring as the existing one is a bit hard. Also fitting a new seal and o-ring to the tacho drive.
#40 PostAuthor: Ultim8pc » Sun Aug 06, 2017 9:14 pm
Finally well enough to get more work done.
Carbs all re-assembled, with float valves, o-rings and gaskets.
I also removed the sump, cleaned it up and the front of the crankcases, fitted new oil pump and oil filter o-rings.
No debris in the sump (just some thick oily gunge) and no crap in the pump gauze.
#41 PostAuthor: Ultim8pc » Thu Dec 14, 2017 4:04 pm
Been a bit busy with other stuff, but I have been doing some work as time permits:
Stripped out the wheels, forks and swing arm and cleaned everything up.
Bought a new battery and also managed to pick up a very nice condition Kerker to replace the tatty one that's currently fitted.
Need to buy a standard seat cover and I have discovered that the rear brake return spring is broken, so will need to get one.
Hoping to get it all reassembled by Christmas and then I can start on getting it registered!
#42 PostAuthor: Ultim8pc » Sat Dec 30, 2017 11:27 am
A bit more progress:
Not had much time as I have been busy setting up a new business venture.
However, bought a return spring and a seat cover. Managed to salvage a good OEM seat foam from another seat which has a rotted base and non-standard cover. So I'll get on with recovering it this week.
#43 PostAuthor: Ultim8pc » Sun Jan 28, 2018 9:55 pm
Got quite a bit done since the last update.
Used the original base and used an original foam from another seat with a crappy base and fitted a new cover. Not a bad job if I say so myself
Reassembled all the rear end of the bike and electrics.
Used Quick-Glo P3-Ultra (plug-plug) to clean up and refinish the rear inner mudguard, tools carrier, airbox and document holder.
Also, refitted the drive shaft cover after fitting new oil seals.
Starting to look like a bike again. With a fair wind I can get it finished this week!
#44 PostAuthor: Ultim8pc » Sun Jan 28, 2018 9:59 pm
Oh and I swapped the carb pairs around so the air screws were facing the right way. :oops:
And fitted new fuel T-pieces while I was at it, even though the ones removed didn't look too bad.
#45 PostAuthor: Ultim8pc » Tue Feb 20, 2018 11:32 pm
Work done since last update:
Carb float heights set and carbs refitted to bike
swing arm, and rear wheel refitted
New foot peg mount rubbers fitted
Front brake caliper stripped and new pads fitted
Engine cleaning work
Trimmed excess material from new seat cover and glued down edges to base
Currently stripping the tatty lacquer from the front forks
Not long till it's finished!
Users browsing this forum: Andy Rocket and 22 guests
