Z650 side stand
Gus
Z650 side stand
#1 PostAuthor: Gus » Tue Feb 07, 2017 6:15 pm
Thought I'd ask here first as I'm not a member of any 650 sites.
My mate needs one of those confounded double spring side stands complete.
Would anyone have one that they would be willing to part with?
Gus
"Set the GRINDER on it"
#2 PostAuthor: warren3200gt » Tue Feb 07, 2017 7:37 pm
Later model than anything Ive got. Post an add here. Some one will have what you need.
http://z650.proboards.com/threads/recent
#3 PostAuthor: warren3200gt » Wed Feb 08, 2017 11:02 pm
Gus
#4 PostAuthor: Gus » Thu Feb 09, 2017 9:46 am
Hi Warren.
Thanks for the link. I got in touch with Tania and asked her if she had one and that is what she listed.
Doesn't look like the right spring to me and one spring is missing.
I'm trying to get one complete instead of faffing around buying individual springs etc that may not be right.
I'll have to register on the 650 site and ask on there.
Gus
#5 PostAuthor: warren3200gt » Thu Feb 09, 2017 11:00 am
Gus, I think faffing will be the only way your end up with what you need. They never normally have any springs with the stand or if they do they'll be rusty as fuck so will need replacing anyway.
Grab it whilst its there and sort the springs separately.
Gus
#6 PostAuthor: Gus » Thu Feb 09, 2017 11:04 am
I'm gonna go home and see if I can add a spigot to the right hand side of the mounting point, cut away the interfering section and fit a stock stand.
Will update
Gus
#7 PostAuthor: warren3200gt » Thu Feb 09, 2017 11:28 am
You know it makes sense.
Charlie
#8 PostAuthor: Charlie » Thu Feb 09, 2017 12:29 pm
IIRC those twin spring stands fitted on the later models were only there cos they had an idiot style stand cut off to stop you riding away with the stand down.
Just bypass that switch and use a conventional sidestand. Better still, get hold of a KE125 side stand like I did, cut it to the correct length and then the bike will no longer sit at 45 degrees as most do on stock sidestand setups :lol:
Gus
#9 PostAuthor: Gus » Thu Feb 09, 2017 1:32 pm
Hi Charlie.
The problem I have is somebody has already bodged a welded effort side stand and stretched bed spring on to the bike already and it won't stay down on its own.
A standard stand wont travel through its own arc because it fouls on the mounting.
I'll have to cut away the mounting and position a pivot somewhere to accept the old style spring
Gus
