900A4 carb bowls removal
hi all,
I'm blessed (!) with small hands/fingers. My 900A4 could do with the float bowl gaskets on cyls 1 and 2 being replaced (persistent fuel weep despite attempts to check tightness of screws with a 90deg angled screwdriver - not a brilliant fit).
Is it possible to do this with the carbs in-situ? Anybody have knowledge of a screwdriver small enough to do the task?
thanks
thanks
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
Its easy, i use a very small phillips with a hole drilled and a tommy bar through,or a phillips and small socket wrench,put a towel under neath to catch screws,fuel etc.if leaking though you may well have float level issue.Paul J
Steve Cooke
- ZedHead
small ratchet driver
https://www.amazon.co.uk/Rolson-Offset- ... 0RZVMZJE5N
bunnysZ wrote:small ratchet driver
Thats the same as one is use as well...
- 8 Valve Mark
carbs
a wee smidge of grease or oil on your float bowl gaskets b4 re-assembly always works for me[/b]
Always a ball ache getting carbs off,on makes it easier if all intake and airbox rubbers supple,take off the starter cover,and the brace across carb tops to get cables off easier,when putting back on only fit centre two airbox rubbers then roll back outer two on them selves and use smooth tyre iron to lever into airbox.
got the little ratchet set today - worked a treat. One loose screw, gave it a tweak, seems to have worked. Good point about the float heights, and I will get round to checking them. Had the fuel pipes off today - noticed that there's a weep from the fuel tap when switched to 'OFF' - looks like the tap's going to need an overhaul as well ..
That can all wait for the next wet weekend - forecast is too good for tomorrow not to take her out for a quick spin
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
good point, bunny..
I'm not such a rivet-counter that swapping to Allen heads would give me sleepless nights
- far better the bike runs sweetly, and I can attend to those little things that always need doing, with the minimum of fuss.
think I'll look for a replacement carb bowls Allen screw set for the 900A4 next time I get a weeping gasket - its bound to happen again at some point!
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
