ZRX 1100 swing arm in a Z1000A frame
Giving up with photo bucket Russ pm me you mobile and I will text some picturs of the swing arm or you can look at the photos on the clubs facebook site.
Rob created a threaded shaft the correct size to centralise the swing arm this allows you to use two m16 bolts to tighten up the swing arm without putting pressure on the bearings.
Cheers Ian
Cheers Ian
PUM 13
Re:
Padders wrote:Giving up with photo bucket Russ pm me you mobile and I will text some picturs of the swing arm or you can look at the photos on the clubs facebook site.
Cheers Ian
Can I get a set of those piccies off you please Ian/
Cheers Gus
"Set the GRINDER on it"
Re:
Cheers Ian
You can post them here Padders without using Photobucket then we can all see them.
Facebook is in the business of trying to replace websites like this with itself...
Users browsing this forum: No registered users and 110 guests
