Hi, I am working through a Unitack head measuring everything up vs the manual guidelines for standard range and service limit. Most parts are covered but no free spring length in given for inner/outer valve springs, just squareness. Also no OD or wear limit is provided for the cam followers/buckets/tappets...whatever they are called...
Anybody have some spec numbers they work to?
Unitrack valve gear dims
Matt C
Z1000J2 / ZRX1200R / Z650B1 / GPz1170B1 x 2
