Discs
jez1100r
Discs
#1 PostAuthor: jez1100r » Wed Mar 15, 2017 6:51 pm
Hi does anyone know if z1100r share front discs with other models . as always most z / GPz models listed discs but do not include z1100r
As mine is 18" front wheel the other z/GPz are 19" frount wheel will that matter
pluto
Re: Discs
#2 PostAuthor: pluto » Wed Mar 15, 2017 9:30 pm
You need discs off the B2, they are a bigger diameter than those fitted to the B1, the unitrac is totally different. I have an 1100r wheel on my B2 with EBC B2 discs which are excellent.
gpzer
Re: Discs
#3 PostAuthor: gpzer » Wed Mar 15, 2017 9:58 pm
if you need to buy a decent used original set of b2 discs john browse motorcycles of wrexham tel 01978 355556 will sort you out ,i recently got a really smart pair for my b2 he,s a very helpful and knowledgeable bloke . :)
GPZ1100 B2 OWNER
jez1100r
Re: Discs
#4 PostAuthor: jez1100r » Fri Mar 17, 2017 1:06 pm
Thank you have a look at b2 then
Jumbo
Re: Discs
#5 PostAuthor: Jumbo » Fri Mar 17, 2017 7:45 pm
I was curious about these ones as from the advert picture I assume that they are the same looking as the originals as a lot of the replacement discs such as EBC are a different look.
http://www.ebay.co.uk/itm/351386938421? ... EBIDX%3AIT
LE to JOG on a z900
P.U.M.
jez1100r
Re: Discs
#6 PostAuthor: jez1100r » Sat Mar 18, 2017 4:01 pm
Thank you but they 270mm. Mine are 280mm
