Guys,
These look to be the same except for ST ones being chrome and MK2 being black, so part numbers can't help.
Can anyone confirm one way or the other?
Thanks,
MK2 v ST headlamp brackets
needaz1100r
- ZedHead
Mark.
Mark.
Re: MK2 v ST headlamp brackets
I only know the fork diameters are different (40mm on the ST to 36mm on the MK2) which may confirm if they'll fit or not? The two bikes don't share much at all unfortunately.
1979 Z1000ST
Redbeard wrote:I only know the fork diameters are different (40mm on the ST to 36mm on the MK2) which may confirm if they'll fit or not? The two bikes don't share much at all unfortunately.
as redbeard has said the st forks are 40mm the headlamp brackets are a bigger diameter & taller
needaz1100r
- ZedHead
Great, thanks guys.
Now to find a set of mk2 headlamp brackets....
Mark.
Mark.
needaz1100r
- ZedHead
- paul doran
needaz1100r
- ZedHead
Users browsing this forum: zapo and 76 guests
