The filter I got out of my A4 was metal and a bit longer
So whats going on.... is the bigger one for a Z1000J... (HF126?) can either be used?
Ginger Bear wrote:I can't believe you ain't fitting genuine Kawasaki, now you've become Mr 'Bog standard'.
zed1015 wrote:Some of the early 900's took the shorter 401 filter which was superseded by the 126.
The early oil filter bolt was different too with the circulation holes positioned higher up.
It's ok to use the 126 in all models of 900/1000 but don't use the shorter 401 in the later bikes as the holes in the bolt are lower down and the oil will bypass the filter.
z1bman wrote:the 401 filter is not for any of the 900 or z1000 range its fitted from the z1000j on wards & is the most popular filter kawasaki do
Pigford wrote:z1bman wrote:the 401 filter is not for any of the 900 or z1000 range its fitted from the z1000j on wards & is the most popular filter kawasaki do
WRONG!!!
Just looked it up and the HF401 is stated as suitable for the Z900A4 http://www.hiflofiltro.com/catalogue/model/1093![]()
http://www.hiflofiltro.com/catalogue/filter/HF401
Clear as mud
z1bman wrote:Pigford wrote:z1bman wrote:the 401 filter is not for any of the 900 or z1000 range its fitted from the z1000j on wards & is the most popular filter kawasaki do
WRONG!!!
Clear as mud
i don't care what they say on the hiflow listing they are wrong as an ex kawaski mechanic going back to 1976 i know what i am talking about
Users browsing this forum: zapo and 76 guests
