Oil Filter dilema
Oil Filter dilema
#1 PostAuthor: Pigford » Mon Apr 03, 2017 7:46 pm
Okay.... Hi-Flo reckon the correct oil filter for a Z900A4 is 401
The filter I got out of my A4 was metal and a bit longer :??
So whats going on.... is the bigger one for a Z1000J... (HF126?) can either be used?
Re: Oil Filter dilema
#2 PostAuthor: z1bman » Mon Apr 03, 2017 7:57 pm
HF126 is what you need
#3 PostAuthor: Pigford » Mon Apr 03, 2017 9:00 pm
fanx
#4 PostAuthor: Ginger Bear » Tue Apr 04, 2017 6:56 am
I can't believe you ain't fitting genuine Kawasaki, now you've become Mr 'Bog standard'. :oops
# 104
#5 PostAuthor: Pigford » Tue Apr 04, 2017 7:28 am
Ginger Bear wrote:I can't believe you ain't fitting genuine Kawasaki, now you've become Mr 'Bog standard'. :oops
Not at those prices :??
#6 PostAuthor: Al » Tue Apr 04, 2017 8:09 am
401 is the J size filter :kod
#7 PostAuthor: zed1015 » Tue Apr 04, 2017 8:25 am
Some of the early 900's took the shorter 401 filter which was superseded by the 126.
The early oil filter bolt was different too with the circulation holes positioned higher up.
It's ok to use the 126 in all models of 900/1000 but don't use the shorter 401 in the later bikes as the holes in the bolt are lower down and the oil will bypass the filter.
#8 PostAuthor: Pigford » Tue Apr 04, 2017 5:18 pm
zed1015 wrote:Some of the early 900's took the shorter 401 filter which was superseded by the 126.
Great advice as usual, cheers Rob :wink:
#9 PostAuthor: ZedHead » Tue Apr 04, 2017 5:32 pm
#10 PostAuthor: z1bman » Tue Apr 04, 2017 5:54 pm
the 401 filter is not for any of the 900 or z1000 range its fitted from the z1000j on wards & is the most popular filter kawasaki do
#11 PostAuthor: Pigford » Tue Apr 04, 2017 5:59 pm
z1bman wrote:the 401 filter is not for any of the 900 or z1000 range its fitted from the z1000j on wards & is the most popular filter kawasaki do
WRONG!!!
Just looked it up and the HF401 is stated as suitable for the Z900A4 http://www.hiflofiltro.com/catalogue/model/1093 :oops
http://www.hiflofiltro.com/catalogue/filter/HF401
Clear as mud :shock:
#12 PostAuthor: z1bman » Tue Apr 04, 2017 6:19 pm
WRONG!!!
i don't care what they say on the hiflow listing they are wrong as an ex kawaski mechanic going back to 1976 i know what i am talking about
#13 PostAuthor: Pigford » Tue Apr 04, 2017 6:30 pm
z1bman wrote:
WRONG!!!
Okay - I'll bow to your experience & knowledge and play safe & NOT use them - thanks for your help.
#14 PostAuthor: z1bman » Tue Apr 04, 2017 6:36 pm
if you want to use a hiflow filter this is the correct one to use http://www.hiflofiltro.com/catalogue/filter/hf126
#15 PostAuthor: Pigford » Tue Apr 04, 2017 7:29 pm
:D
