Harris road baffle
davido
Harris road baffle
#1 PostAuthor: davido » Tue Apr 04, 2017 2:18 pm
The race baffle in my Harris sounds a bit too enthusiastic! Anybody got a road baffle in reasonable nick?
http://www.kzrider.com/forum/11-project ... ject-build
KZ1000CSR
GSF600Bandit
CBX750F
CB550F
Julian_Boolean
Re: Harris road baffle
#2 PostAuthor: Julian_Boolean » Tue Apr 04, 2017 2:54 pm
I haven't got one, but from memory they're quite restrictive you might be better off with a dB killer in the baffle you have
davido
#3 PostAuthor: davido » Tue Apr 04, 2017 3:29 pm
Thanks Julian but would a db killer not also restrict the exhaust? Are db killers brand specific? Do I need/can I get one for a Harris or are they universal?
Julian_Boolean
#4 PostAuthor: Julian_Boolean » Tue Apr 04, 2017 3:53 pm
I think they're fairly universal, the Harris race baffle is just a 50mm perforated tube, so any 50mm dB killer would fit.
The Harris road baffle is 3 tubes in a plate and then another tube that exits at the rear, it's pretty simple.
When I had a Harris I looked at reducing the 50mm tube to a 38mm one, quite easy to do as you can run the smaller tube up the centre of the bigger one and use exhaust putty to hold it in place as a temporary measure, my intention was to get 50 - 38 reducers made (basically big washers) but the GSX750 it was on knocked it's big ends out at Santa Pod before I got round to finishing it back in 1989.
#5 PostAuthor: chrisNI » Tue Apr 04, 2017 9:32 pm
This is one :D I found it a couple of days ago looking for stuff I seem to have lost - it's black chrome with a couple of small dents it's an original Harris from about 1983 so it's 100% solid. It would tidy - the chrome would polish up. It's been in the shed for about 20 years the actual Harris is now on my brother's bike wth a loud baffle... If you're interested PM me :rock
1962royp
#6 PostAuthor: 1962royp » Wed Apr 05, 2017 8:11 am
try this ebay
192122197417
Seller assumes all responsibility for this listing.
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
jules
#7 PostAuthor: jules » Sun Apr 09, 2017 7:29 pm
have a couple of chrome ones I was just about to list if it's not to late!
P.U.M
'78 z1000a2,'83 1000r,'76 Z900a4,07 gsxr1000k6,'01 bj250,'03 husky 450,'83 Z1170r Lawson.
Gonzo
#8 PostAuthor: Gonzo » Wed Nov 27, 2019 6:40 pm
Just reigniting this old post as I would like to get my road baffle out and butcher it to make a race baffle (if that can be done).
First problem is getting the damn thing out of the exhaust - it seems to be stuck solid and there is no screw holding it in either. Any ideas?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
moizeau
#9 PostAuthor: moizeau » Wed Nov 27, 2019 6:48 pm
Is there as rivet on the inside?
Gonzo
#10 PostAuthor: Gonzo » Wed Nov 27, 2019 7:40 pm
moizeau wrote:Is there as rivet on the inside?
No, nothing holding it in except friction!
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
#11 PostAuthor: kev edwards » Wed Nov 27, 2019 8:22 pm
Years ago i made up a slide hammer to pull one out that would not shift, it worked for me, i have a slightly modified road baffle in my harris style exhaust, its a bit freer flowing and louder but not to the point of getting a tug from plod.
