4 main terminal blocks
Big Fluff
#1 PostAuthor: Big Fluff » Wed Apr 26, 2017 8:37 pm
I need to replace the four coloured terminal blocks on a customers Z1R-TC as they're held together with cable ties!
I'm talking about the white, blue, brown and green connector housings beneath the LH side panel.
I've done a search and it looks like Z-Power and VWP no longer offer them.
Can anyone help please?
Will
Re: 4 main terminal blocks
#2 PostAuthor: paul doran » Wed Apr 26, 2017 8:39 pm
Will I should have I am off tomorrow so I will take a look
#3 PostAuthor: z1bman » Wed Apr 26, 2017 8:54 pm
Big Fluff
#4 PostAuthor: Big Fluff » Thu Apr 27, 2017 10:43 am
Thanks Paul. It's actually the female sockets I need; namely the brown socket from the main harness and the white socket from the rectifier, so the link harness that Z1Bman posted won't do unfortunately.
I will post a picture later.
Regards Will
#5 PostAuthor: ZedHead » Thu Apr 27, 2017 2:01 pm
I have tried all over to find the female plugs. So far to no avail :(
Kwackman
#6 PostAuthor: Kwackman » Thu Apr 27, 2017 2:20 pm
Are these any use?
https://goo.gl/dVBXhJ
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
KeithZ1R
#7 PostAuthor: KeithZ1R » Thu Apr 27, 2017 2:26 pm
how good do they need to be and do they need the wiring attached ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
DavidZ1R
#8 PostAuthor: DavidZ1R » Thu Apr 27, 2017 4:57 pm
I searches in vain for them will, could not find anywhere, if you find any let me know please.
Coose
#9 PostAuthor: Coose » Thu Apr 27, 2017 6:54 pm
Big Fluff
#10 PostAuthor: Big Fluff » Thu Apr 27, 2017 9:27 pm
KeithZ1R wrote:how good do they need to be and do they need the wiring attached ?
They just need to be unbroken. I can easily remove the terminals so no wires needed. Hope you can help, just need the brown and white female socket housings. Thanks
Big Fluff
#11 PostAuthor: Big Fluff » Thu Apr 27, 2017 9:29 pm
Kwackman wrote:Are these any use?
No, wrong ones .
Jay1969
#12 PostAuthor: Jay1969 » Thu Apr 27, 2017 10:04 pm
#13 PostAuthor: z1bman » Thu Apr 27, 2017 10:08 pm
you need to get a scrap or used harness & rectifier with good block connectors other than buying new you will struggle to find them
#14 PostAuthor: paul doran » Fri Apr 28, 2017 8:03 am
Can You put up a picture Will
KeithZ1R
#15 PostAuthor: KeithZ1R » Fri Apr 28, 2017 8:12 am
ive some somewhere :) I will look when I get back home at weekend and get back to you
Keith
:bop :gom
mistaken.
