Unitrak Gearbox Sprocket lock washer
martinz1000r
#1 PostAuthor: martinz1000r » Sat May 13, 2017 11:53 am
Please excuse silly question.....
Lock washer for the Unitrack gearbox sprocket nut is dished. Which way round should it go? Does the nut sit in what is a concave shape or should it be the other way round? Can't tell from the parts diagram and I've loaned my workshop manual to someone.
Re: Unitrak Gearbox Sprocket lock washer
#2 PostAuthor: Al » Sat May 13, 2017 1:53 pm
This is the pic from the Unitrak manual.
Is the sprocket off-set and dished inside causing the washer to be dished?
According to this it appears flat!
martinz1000r
#3 PostAuthor: martinz1000r » Sat May 13, 2017 2:41 pm
Thanks Al, it is dished but I suspect as torqued down it will flatten out allowing the edge to be bent over as per the picture
#4 PostAuthor: zed1015 » Sat May 13, 2017 3:20 pm
If it's dished you always fit them with the dished centre facing out towards the nut.
