Cylinder head
jovin04
Cylinder head
#1 PostAuthor: jovin04 » Fri May 26, 2017 4:59 pm
Hi can anyone recommend (a good engineer) my gpz1100 unitrac head appears to have very worn valve seats. I can no longer get a valve clearances required. It also looks like someone has shaved the tops of the valves to overcome this issue. I don't want to bin the head as there now getting rare.
Julian_Boolean
Re: Cylinder head
#2 PostAuthor: Julian_Boolean » Fri May 26, 2017 5:07 pm
Try Chris Tombleson at Grumpy 1260
Re: Cylinder head
#3 PostAuthor: ZedHead » Fri May 26, 2017 5:44 pm
Buzzard is our man for cylinder heads I know he is very busy right now
Re: Cylinder head
#4 PostAuthor: zed1015 » Fri May 26, 2017 6:13 pm
There's a few options to reclaim your head.
Either go the whole hog and fit new valves and seats (not a hard job for any engine re-conditioners or competent home mechanic.) or simply fit bigger valves and re-cut the seats.
The latter is the most common fix and the main reason most zeds get them fitted rather than for performance gains.
Fitting bigger valves puts the valve seating area on to the un-worn wider radius of the seat which should get your clearance back and put the shims back in the thick end of the range.
jovin04
Re: Cylinder head
#5 PostAuthor: jovin04 » Fri May 26, 2017 6:44 pm
Hi do you know where I could get the over size valves?
Re: Cylinder head
#6 PostAuthor: zed1015 » Fri May 26, 2017 8:40 pm
APE or Manley etc sell them.
Either get them direct from the states via Pitstop Performance or Z1ENT etc or over here from one of the performance shops, Debbens etc or probably from Saisie and then of course there is always EBAY.
8 Valve Mark
Re: Cylinder head
#7 PostAuthor: 8 Valve Mark » Sun May 28, 2017 12:19 am
i don't know if it's compatible,but i have an 1100b1 head (complete) although it might be a 1000j head in my shed that i could live without if it's of use ? was previously in a good running (crashed)bike about 1991 about 16,18 000 miles as i remember..i understand the uni has uprated cam's and the 1000j (998cc)has slightly larger valves than the 1015cc z1000 but i don't know offhand if it's a match.. if so let me know.. mark
garyd
Re: Cylinder head
#8 PostAuthor: garyd » Sun May 28, 2017 6:35 am
I'm sure you know....but the unitack head has different combustion chamber shape...which is why it's sought after.
Doubt the J head would be a good alternative.
8 Valve Mark
Re: Cylinder head
#9 PostAuthor: 8 Valve Mark » Sun May 28, 2017 12:17 pm
i didn't know that Garry.never had a unitrack cheers
8 Valve Mark
Re: Cylinder head
#10 PostAuthor: 8 Valve Mark » Sun May 28, 2017 12:22 pm
thanks Gary i know now you've told me. not much help at all.
jovin04
Re: Cylinder head
#11 PostAuthor: jovin04 » Sun May 28, 2017 1:05 pm
Thanks for your help chaps
garyd
Re: Cylinder head
#12 PostAuthor: garyd » Sun May 28, 2017 4:51 pm
8 Valve Mark wrote:thanks Gary i know now you've told me. not much help at all.
Sorry. the first post was about a unitrac head....didn't spot the conversation had moved.
